Hello,
I have a python addin which has a combobox and a series of buttons. I added some code so that depending upon what's selected from the combobox, the buttons are either enabled or disabled. It's working fine except for one button (cleanupdatabtn). In all cases this button does not enable or disable. I've checked many times and the spelling is correct. I'm at a bit of a loss for what I'm missing, maybe someone can see something here that I don't.
Thanks!
class ApplicationType(object):
"""Implementation for PlanningTools_addin.applicationtypecmb (ComboBox)"""
def __init__(self):
self.items = ['Community Boundary Change','Development Permit','Disposal of Reserve',
'Land Use Amendment','New Community Proposal','Outline Plan','Road Closure',
'SDAB','Street Name Change','Subdivision','Export Map Window as JPEG']
self.editable = True
self.enabled = True
self.dropdownWidth = 'WWWWWWWWWWWWWWWWWWWW'
self.width = 'WWWWWWWWWWWWWWWWWWWW'
def onSelChange(self, selection):
if selection in ('Community Boundary Change','Development Permit','Disposal of Reserve',
'SDAB','Street Name Change','Subdivision'):
setupprojectbtn.enabled = True
setupparcelbtn.enabled = False
reviewmapbtn.enabled = False
createimagebtn.enabled = False
cleanupdatabtn.enabled = True
elif selection == 'Land Use Amendment':
setupparcelbtn.enabled = True
reviewmapbtn.enabled = True
createimagebtn.enabled = True
cleanupdatabtn.enabled = False
elif selection == 'Export Map Window as JPEG':
setupprojectbtn.enabled = False
else:
pythonaddins.MessageBox('something is wrong','e',0)
