Python - Calculate Number of Days Between Dates
2543
10-01-2014 10:55 AM
JasonSmith
Hello all,
I am new to python and am trying to switch away from VBA which I had only used in excel. I have a program in excel that basically does hot spot analysis, but am trying to convert the exact same process into ArcGIS.
What I am trying to do is look at record 1 "date_occur" field and calculate the difference in days from record 2. Eventually this will be a loop and data will be written and deleted, but want to start off by learning the basics first.
Tags (3)
DanPatterson_Retired
There are variety of calculating the difference between dates using the datetime module   see one example
