Python Date Stamping
4753
13
10-20-2014 08:03 AM
StephenEldridge
Anyone know how to make python put a date stamp on a filename when creating a feature?
Steve
StephenEldridge
Here is how I had to code it:
import time
from datetime import Date
#Sets a variable to hold today's date
currentdate = today()
  1. Process: Feature Class to Feature Class (6)
arcpy.FeatureClassToFeatureClass_conversion(in, out loc, "output_"+str(currentdate)
The result is: output_2014-10-23
The “-“ causes failure as an invalid character
BrandonKeinath1
Hi Steve,
Can you clarify your question a little?  Are you looking to put a date stamp on a new feature class?  I've written a few scripts that utilize dates and times and the method changes a little based on where you want to put the data.  Let me know and I can try to help.
Brandon
StephenEldridge
Hi Brandon,
Yes on a new feature class.  I am running a feature to feature script that filters specific data for each feature and I need to date stamp them so that I can view changes in a side by side comparison and the output goes into a File Geodatabase.
Steve
BrandonKeinath1
And you would like the date stamp to be on the feature class?  So you could check today's "River" export against yesterday's "River" feature class?  If I'm understanding you right then I would suggest importing datetime.  Depending on how you want to format the date you have some options shown here 8.1. datetime — Basic date and time types — Python 2.7.8 documentation
import datetime
#Set a variable to hold today's date
currentdate = datetime.date.today()
#Execute the feature to feature function.  Casting as a string just to be safe
arcpy.FeatureClassToFeatureClass_conversion(in_features, out_path, out_name + str(currentdate))
StephenEldridge
Yes, that is basically what I am trying to do, I will give that a try and let you know how it goes.
Thanks for your quick responses,
Steve
BrandonKeinath1
You're welcome and good luck.  If it gives you trouble let me know and I can try to help.
Brandon
StephenEldridge
StephenEldridge
Good morning Brandon,
I figured out how to send the string to the feature output but the format is 2014-10-23 and I need it to be 20141023. I have read through documentation and have not been able to figure out how to do this format could you please assist?
Steve
BrandonKeinath1
Happy to,
I'm not sure how you ended up coding it but you can modify your date object with .strftime which lets you tell the date objects how to orient themselves.  There is a really good reply on stack overflow datetime - How to print date in a regular format in Python? - Stack Overflow
But in your case I would say code like currentdate.strftime(%Y%b%d) should format it the way you want.  You can reference the formatting letters in either the link or the help for strftime.
Good luck,
Brandon
StephenEldridge
import time
