Hello @BlakeTerhune Please see screenshots and python script. i also set it up on task scheduler. it was working running since September 2021 until stop recently. I haven't change any script and task scheduler. For some reasons, my zip file 'PaFiles.gdb' stopped working. I found out that the last time inside that zip file, it ran populated on Jan. 2022 but everything else is fine. Please advise. Thank you for your help.
from arcgis.gis import GIS
# Python Standard Library Modules
from pathlib import Path, PurePath
from zipfile import ZipFile
public_data_item_id = '123'
anon_gis = GIS(username="123", password="123")
data_item = anon_gis.content.get(public_data_item_id)
data_path = Path('C:\123')
if not data_path.exists():
data_path.mkdir()
zip_path = data_path.joinpath('PAData.zip')
extract_path = data_path.joinpath('PADataDatasets')
with ZipFile(zip_path, 'r') as zip_ref:
zip_ref.extractall(extract_path)
data_item.download(save_path=data_path)
print (PurePath(zip_path))
data_path = Path('C:\123\PADataDatasets\PA_Data')
data_path.mkdir()
zip_path = data_path.joinpath('PaFiles.gdb.zip')
extract_path = data_path.joinpath('PaFiles.gdb')
