Trying to calculate a field within a model builder process, and I am getting returns I was not expecting. I am trying to have the Null values calculated as 0s (Number field). Now, the non-Null values are being calculated to 0s and leaving the Null values.
Hello Matt,
You probably need to add an else in there and check for the field equals <null>. Something like:
expression:
nullfill(!FREQUENCY!)
codeblock:
def nullfill(value): if value == None: return 0 else: return value
Hello Matt,
expression:
codeblock:
That did the trick! Thank you for the help.
