It would be tremendously helpful if someone could post a sample python toolbox (pyt) that accepts a dummy input parameter or two, and returns "hello world of pyt gp services!" I figure with that template, I could do my own gp routines during the execution, and replace the "hello world" with the results of my gp work. I don't need any geometry returned, just text.
The use case here is to return nearby addresses from an input lat/long.
This code fails:
import arcpy
import os
class Toolbox(object):
def __init__(self):
self.label = "Get Nearby Addresses"
self.alias = ""
# List of tool classes associated with this toolbox
self.tools = [GetNearbyAddresses]
class GetNearbyAddresses(object):
def __init__(self):
self.description = "Get Nearby Addresses within a buffer."
self.canRunInBackground = False
def getParameterInfo(self):
params = []
param0 = arcpy.Parameter(
displayName = "Latitude",
name = "lat",
datatype = "Double",
parameterType = "Required",
direction = "Input")
params.append(param0)
param1 = arcpy.Parameter(
displayName = "Longitude",
name = "lon",
params.append(param1)
param2 = arcpy.Parameter(
displayName = "Buffer Distance",
name = "distance",
datatype = "Long",
params.append(param2)
param3 = arcpy.Parameter(
displayName = "Address List",
name = "addresses",
datatype = "GPString",
parameterType = "Derived",
direction = "Output")
params.append(param3)
return params
def execute(self, parameters, messages):
try:
arcpy.env.workspace = r'E:\gis\default.gdb'
lat = parameters[0].valueAsText
lon = parameters[1].valueAsText
distance = parameters[2].valueAsText
#inpoint = arcpy.Point(X=lon, Y=lat)
#ptGeometry = arcpy.PointGeometry(inpoint, arcpy.SpatialReference(4326))
#arcpy.Buffer_analysis(ptGeometry, 'buffer', distance + ' FEET', \
# "FULL", "ROUND", "NONE", "")
#get intersecting addresses here
parameters[3].value = 'a nice list of addresses!' # I need this from a gp service!
return
except Exception, ErrorDesc:
sErr = "ERROR:\n" + str(ErrorDesc)
messages.addErrorMessage(sErr)
return
