Hello,I'm trying to calculate a Global Moran's I statistic on a [long] list of point files using python. I have set up my code to loop through the arcpy.SpatialAutocorrelation_stats script as shown below. The loop runs through the first shapefile without a problem and prints out the Moran's I Summary Table. When it gets to the second shapefile, it crashes with a strange error. I can manually run the Spatial Autocorrelation Script in batch form without a problem from ArcCatalog. However, I don't want to parse through the Results window later. I am using ArcGIS 10.1 with Python XY (Spyder) 2.7 on a Windows 7 64-bit machine.Has anyone encountered this error or found any solutions?Thanks,Andy
import arcpy
dataPath = r"c:\data"
elevationPoints = ["elevPts1.shp", "elevPts2.shp"]
elevationPoints = ["id_1pt.shp","id_11pt.shp"]
dataPath = r"C:\Users\Andy\Desktop\BlackbirdKnob_WV\tempPts"
for i in range(len(elevationPoints)):
arcpy.SpatialAutocorrelation_stats (dataPath+"\\"+elevationPoints, "GRID_CODE", "NO_REPORT" , "FIXED_DISTANCE_BAND", "EUCLIDEAN_DISTANCE" ,"NONE","15")
This is the error message that comes up:
File "C:\Users\Andy\Desktop\MoransLoop.py", line 20, in <module>
File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\stats.py", line 403, in SpatialAutocorrelation
raise e
arcgisscripting.ExecuteError:
File "c:\program files (x86)\arcgis\desktop10.1\ArcToolbox\Scripts\MoransI.py", line 21, in <module>
import SSReport as REPORT
File "c:\program files (x86)\arcgis\desktop10.1\ArcToolbox\Scripts\SSReport.py", line 17, in <module>
import pylab as PYLAB
File "C:\Python27\lib\site-packages\pylab.py", line 1, in <module>
from matplotlib.pylab import *
File "C:\Python27\lib\site-packages\matplotlib\pylab.py", line 264, in <module>
from matplotlib.pyplot import *
File "C:\Python27\lib\site-packages\matplotlib\pyplot.py", line 23, in <module>
from matplotlib.figure import Figure, figaspect
File "C:\Python27\lib\site-packages\matplotlib\figure.py", line 18, in <module>
from axes import Axes, SubplotBase, subplot_class_factory
File "C:\Python27\lib\site-packages\matplotlib\axes.py", line 338, in <module>
class Axes(martist.Artist):
File "C:\Python27\lib\site-packages\matplotlib\axes.py", line 2051, in Axes
def grid(self, b=None, which='major', axis='both', **kwargs):
File "C:\Python27\lib\site-packages\matplotlib\docstring.py", line 103, in dedent_interpd
return interpd(dedent(func))
File "C:\Python27\lib\site-packages\matplotlib\docstring.py", line 36, in __call__
func.__doc__ = func.__doc__ and func.__doc__ % self.params
KeyError: 'Line2D'
Failed to execute (SpatialAutocorrelation).
