Hello!I am have already posted this in the general forum but i managed to solve that issue and now i have a new one!I keep getting an error 99999 error message at line 37!( gp.RasterToPolygon_conversion(INPUT_RASTER, Output_polygon_features, "SIMPLIFY", "VALUE") )I am trying to make a script which selects every .png file in a folder beginning with the letters "LG". I then want the scipt create a shapefile, replacing the "LG" with "SH", and then i want the script to buffer that shapefile and rename the buffer with the first 2 letters being "SB"!Can anyone see why this isnt working? I am very, very new to this and have been staring at this script pulling out my hair for days!! 😮Here is the script:# ---------------------------------------------------------------------------
# RASTER2POLYGON.py
# Created on: Wed Dec 01 2010 12:20:48 PM
# (generated by ArcGIS/ModelBuilder)
# Usage: RASTER2POLYGON <INPUT_RASTER> <Output_polygon_features> <Raster_Buffer_shp>
# Import system modules
import sys, string, os, arcgisscripting
# Create the Geoprocessor object
gp = arcgisscripting.create()
# Load required toolboxes...
gp.AddToolbox("C:/Program Files/ArcGIS/ArcToolbox/Toolboxes/Conversion Tools.tbx")
gp.AddToolbox("C:/Program Files/ArcGIS/ArcToolbox/Toolboxes/Analysis Tools.tbx")
# Script arguments...
folder = "D:\\J04-0083\\IMAGEFILES"
for root, dirs, filenames in os.walk(folder): # returms root, dirs, and files
for filename in filenames:
filename_split = os.path.splitext(filename) # filename and extensionname (extension in [1])
filename_zero = filename_split[0]
try:
first_2_letters = filename_zero[0] + filename_zero[1]
except:
first_2_letters = "XX"
if first_2_letters == "LG":
Output_polygon_features = "D:\\J04-0083\\ShapeFiles.gdb\\" + "SH_" + filename + ".shp"
# Process: Raster to Polygon...
INPUT_RASTER = os.path.join(root + "\\" + filename_zero + ".png")
Distance__value_or_field_ = "5 Meters"
Raster_Buffer_shp = "SB_" + filename + ".shp"
# Process: Buffer...
gp.Buffer_analysis(Output_polygon_features, Raster_Buffer_shp, Distance__value_or_field_, "FULL", "ROUND", "NONE", "")
