I have created a model that will select features in an enterprise db and export to a dbf table. This feature class is versioned and when edited, the updated data is not automatically recognized when I run the model. I need to refresh the database (in ArcCatalog, right click db connection > refresh) before the feature class table will update. Is there a tool that I can add to modelbuilder that will refresh the database before the Table Select tool runs so that it is running on updated data. Ultimately this needs to run as a scheduled task so no manual process should be used.
ArcGIS 10.2.2
SQL Server db
Sharon
