Well that makes it complicated... Dumb question: Is there any change in behaviour if you leave off the default parameters in AddField? For example:arcpy.AddField_management(fc, "AssetObjectId", "LONG")
#instead of
arcpy.AddField_management(fc, "AssetObjectId", "LONG", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")
Is it possible to temporarily disable Forfront, and at least determine that doing so fixes the issue? Maybe your IT people will make an exception for you... mine did for me.FYI: I am running the following code in v10.1 SP0 (and actually running it as 16 seperate concurrent python.exe processesall at the same time using the subprocess module) and it is super stable.#Process: Adds the neccessary fields
arcpy.AddField_management(indxTileFC, "REMSOFT_ID", "LONG"); showGpMessage() #calcs this field in the post-process
arcpy.AddField_management(indxTileFC, "ACCBUFF", "SHORT"); showGpMessage()
arcpy.AddField_management(indxTileFC, "ADMIN_NM", "TEXT", "", "", "20"); showGpMessage()
arcpy.AddField_management(indxTileFC, "COUNTY_NM", "TEXT", "", "", "20"); showGpMessage()
arcpy.AddField_management(indxTileFC, "CLASS_RPT", "TEXT", "", "", "8"); showGpMessage()
arcpy.AddField_management(indxTileFC, "CLASS_MODL", "TEXT", "", "", "8"); showGpMessage()
arcpy.AddField_management(indxTileFC, "DEFER_RSNS", "TEXT", "", "", "60"); showGpMessage()
arcpy.AddField_management(indxTileFC, "DEFER_YR", "SHORT"); showGpMessage()
arcpy.AddField_management(indxTileFC, "DFR_YR_MDL", "SHORT"); showGpMessage()
arcpy.AddField_management(indxTileFC, "DEM_ELV", "SHORT"); showGpMessage()
arcpy.AddField_management(indxTileFC, "DEM_SLP", "SHORT"); showGpMessage()
arcpy.AddField_management(indxTileFC, "DISTRCT_NM", "TEXT", "", "", "20"); showGpMessage()
arcpy.AddField_management(indxTileFC, "EAGLES", "SHORT"); showGpMessage()
arcpy.AddField_management(indxTileFC, "FORESTED", "SHORT"); showGpMessage()
arcpy.AddField_management(indxTileFC, "HCPLND_FLG", "SHORT"); showGpMessage() #added 20120827
arcpy.AddField_management(indxTileFC, "HCPUNIT_NM", "TEXT", "", "", "20"); showGpMessage()
arcpy.AddField_management(indxTileFC, "ITERATION", "TEXT", "", "", "18"); showGpMessage() #edit made for Rod to QC
arcpy.AddField_management(indxTileFC, "LANDCOV_CD", "SHORT"); showGpMessage()
arcpy.AddField_management(indxTileFC, "LANDUSE_CD", "TEXT", "", "", "12"); showGpMessage()
arcpy.AddField_management(indxTileFC, "LCL_NW_ID", "LONG"); showGpMessage()
arcpy.AddField_management(indxTileFC, "LCL_PC_ID", "LONG"); showGpMessage()
arcpy.AddField_management(indxTileFC, "LCL_SPS_ID", "LONG"); showGpMessage()
arcpy.AddField_management(indxTileFC, "LCL_E_FLG", "SHORT"); showGpMessage()
arcpy.AddField_management(indxTileFC, "LCL_F_FLG", "SHORT"); showGpMessage()
arcpy.AddField_management(indxTileFC, "LCL_I_FLG", "SHORT"); showGpMessage()
arcpy.AddField_management(indxTileFC, "LCL_S_FLG", "SHORT"); showGpMessage()
arcpy.AddField_management(indxTileFC, "LCL_DF_YR", "SHORT"); showGpMessage()
arcpy.AddField_management(indxTileFC, "LCL_RP_FLG", "SHORT"); showGpMessage()
arcpy.AddField_management(indxTileFC, "LCL_UP_FLG", "SHORT"); showGpMessage()
arcpy.AddField_management(indxTileFC, "LPU_CD", "SHORT"); showGpMessage()
arcpy.AddField_management(indxTileFC, "LPU_NM", "TEXT", "", "", "30"); showGpMessage()
arcpy.AddField_management(indxTileFC, "LSMS_RIP", "TEXT", "", "", "12"); showGpMessage()
arcpy.AddField_management(indxTileFC, "LSMS_UP", "TEXT", "", "", "12"); showGpMessage()
arcpy.AddField_management(indxTileFC, "LYNX_OID", "LONG"); showGpMessage()
arcpy.AddField_management(indxTileFC, "MGMT_FUND", "TEXT", "", "", "4"); showGpMessage()
arcpy.AddField_management(indxTileFC, "MM_INT_OID", "LONG"); showGpMessage()
arcpy.AddField_management(indxTileFC, "MM_MA_OID", "LONG"); showGpMessage()
arcpy.AddField_management(indxTileFC, "MM_MA_NM", "TEXT", "", "", "50"); showGpMessage()
arcpy.AddField_management(indxTileFC, "MM_PLN_OID", "LONG"); showGpMessage()
arcpy.AddField_management(indxTileFC, "MM_PLN_LBL", "TEXT", "", "", "50"); showGpMessage()
arcpy.AddField_management(indxTileFC, "MM_PLN_STA", "TEXT", "", "", "18"); showGpMessage()
arcpy.AddField_management(indxTileFC, "MM_POL_OID", "LONG"); showGpMessage()
arcpy.AddField_management(indxTileFC, "MM_POL_LBL", "TEXT", "", "", "50"); showGpMessage()
arcpy.AddField_management(indxTileFC, "MM_POL_STA", "TEXT", "", "", "18"); showGpMessage()
arcpy.AddField_management(indxTileFC, "MM_SWA_OID", "LONG"); showGpMessage()
arcpy.AddField_management(indxTileFC, "MM_SWA_TNM", "TEXT", "", "", "50"); showGpMessage()
arcpy.AddField_management(indxTileFC, "MM_SWA_RSN", "TEXT", "", "", "75"); showGpMessage()
arcpy.AddField_management(indxTileFC, "NRF_DISP_O", "TEXT", "", "", "8"); showGpMessage()
arcpy.AddField_management(indxTileFC, "NSO_FH_OID", "LONG"); showGpMessage() #Future habitat areas
arcpy.AddField_management(indxTileFC, "NSO_KC_OID", "LONG"); showGpMessage() #Kilickitat Core
arcpy.AddField_management(indxTileFC, "NSO_KH_OID", "LONG"); showGpMessage() #Klickitat Habitat
arcpy.AddField_management(indxTileFC, "NSO_MGT_CD", "TEXT", "", "", "3"); showGpMessage()
arcpy.AddField_management(indxTileFC, "NSO_MGT_CS", "TEXT", "", "", "21"); showGpMessage()
arcpy.AddField_management(indxTileFC, "NSO_MGT_AR", "TEXT", "", "", "8"); showGpMessage()
arcpy.AddField_management(indxTileFC, "NSOMGT_OID", "LONG"); showGpMessage()
arcpy.AddField_management(indxTileFC, "NSO_NESTP", "TEXT", "", "", "4"); showGpMessage()
arcpy.AddField_management(indxTileFC, "O_CMZ_TY", "TEXT", "", "", "2"); showGpMessage() #OESF CMZ buffer type (i or e)
arcpy.AddField_management(indxTileFC, "O_CMZ_WTY", "SHORT"); showGpMessage() #OESF CMZ water type
arcpy.AddField_management(indxTileFC, "O_OC_DIST", "LONG"); showGpMessage() #OESF distance to ocean (saltwater)
arcpy.AddField_management(indxTileFC, "O_RB_DIST", "SHORT"); showGpMessage() #OESF riparian buffer distance
arcpy.AddField_management(indxTileFC, "O_RB_OID", "LONG"); showGpMessage() #OESF riparian buffer objectid
arcpy.AddField_management(indxTileFC, "O_RB_WTY", "SHORT"); showGpMessage() #OESF riparian buffer water type
arcpy.AddField_management(indxTileFC, "O_SWS_ID", "SHORT"); showGpMessage() #OESF subwatershed identified
arcpy.AddField_management(indxTileFC, "O_SWS_PCT", "FLOAT"); showGpMessage() #OESF percent of subwatershed in DNR's forested managment
arcpy.AddField_management(indxTileFC, "O_SWS_UAC", "FLOAT"); showGpMessage() #OESF subwatershed upland acres (no saltwater)
arcpy.AddField_management(indxTileFC, "O_UNST_SRC", "SHORT"); showGpMessage() #OESF unstable slope data source
arcpy.AddField_management(indxTileFC, "O_UNST_TY", "TEXT", "", "", "2"); showGpMessage() #OESF unstable slope type (i or e)
arcpy.AddField_management(indxTileFC, "O_UNST_WTY", "SHORT"); showGpMessage() #OESF unstable slope water type
arcpy.AddField_management(indxTileFC, "O_WET_TY", "TEXT", "", "", "2"); showGpMessage() #OESF wetland type (i or e)
arcpy.AddField_management(indxTileFC, "OWLS_1R", "LONG"); showGpMessage()
arcpy.AddField_management(indxTileFC, "OWLS_1R_E", "LONG"); showGpMessage()
arcpy.AddField_management(indxTileFC, "OWLS_M1", "SHORT"); showGpMessage()
arcpy.AddField_management(indxTileFC, "OWLS_SW", "SHORT"); showGpMessage()
arcpy.AddField_management(indxTileFC, "PARCEL_ID", "LONG"); showGpMessage()
arcpy.AddField_management(indxTileFC, "PEREGRINES", "SHORT"); showGpMessage()
arcpy.AddField_management(indxTileFC, "PLS_OID", "LONG"); showGpMessage()
arcpy.AddField_management(indxTileFC, "PLS_SEC_NM", "TEXT", "", "", "20"); showGpMessage()
arcpy.AddField_management(indxTileFC, "PLS_TWNRNG", "TEXT", "", "", "8"); showGpMessage()
arcpy.AddField_management(indxTileFC, "REGION_NM", "TEXT", "", "", "20"); showGpMessage()
arcpy.AddField_management(indxTileFC, "RIU_CUR_ID", "LONG"); showGpMessage()
arcpy.AddField_management(indxTileFC, "RIU_MST_ID", "LONG"); showGpMessage()
arcpy.AddField_management(indxTileFC, "RMU_POLYID", "LONG"); showGpMessage()
arcpy.AddField_management(indxTileFC, "ROAD_BUFF", "SHORT"); showGpMessage()
arcpy.AddField_management(indxTileFC, "ROAD_DIST", "LONG"); showGpMessage()
arcpy.AddField_management(indxTileFC, "ROS", "TEXT", "", "", "8"); showGpMessage()
arcpy.AddField_management(indxTileFC, "ROS_ZN_CD", "TEXT", "", "", "2"); showGpMessage()
arcpy.AddField_management(indxTileFC, "SHU_NM", "TEXT", "", "", "12"); showGpMessage() #added 20120905, csny490 - same as OWNGROUP field
arcpy.AddField_management(indxTileFC, "SLPSTB_AC", "FLOAT"); showGpMessage()
arcpy.AddField_management(indxTileFC, "SOMU_CD", "LONG"); showGpMessage()
arcpy.AddField_management(indxTileFC, "SOMU_NM", "TEXT", "", "", "30"); showGpMessage()
arcpy.AddField_management(indxTileFC, "SOMU_PCT", "FLOAT"); showGpMessage()
arcpy.AddField_management(indxTileFC, "SUB_CD", "TEXT", "", "", "8"); showGpMessage()
arcpy.AddField_management(indxTileFC, "SUB_NO", "LONG"); showGpMessage()
arcpy.AddField_management(indxTileFC, "SUB_PCT", "FLOAT"); showGpMessage()
arcpy.AddField_management(indxTileFC, "SUB_UP_AC", "FLOAT"); showGpMessage()
arcpy.AddField_management(indxTileFC, "SUR_OWN_CD", "SHORT"); showGpMessage()
arcpy.AddField_management(indxTileFC, "SUR_OWN_NM", "TEXT", "", "", "50"); showGpMessage()
arcpy.AddField_management(indxTileFC, "TIM_OWN_CD", "SHORT"); showGpMessage()
arcpy.AddField_management(indxTileFC, "TIM_OWN_NM", "TEXT", "", "", "50"); showGpMessage()
arcpy.AddField_management(indxTileFC, "WOGHI_INDX", "FLOAT"); showGpMessage()
arcpy.AddField_management(indxTileFC, "WRIA_CD", "SHORT"); showGpMessage()
arcpy.AddField_management(indxTileFC, "WRIA_NM", "TEXT", "", "", "30"); showGpMessage()
arcpy.AddField_management(indxTileFC, "XACT_TY", "TEXT", "", "", "2"); showGpMessage()
arcpy.AddField_management(indxTileFC, "XACT_OID", "LONG"); showGpMessage()
