SearchCursor Select Attributes Delete Rows
336
03-20-2024 02:59 PM
ModernElectric
Occasional Contributor III
I am trying to figure out how to write a Python script that will use Search Cursor to go thru a Feature Class based on a list of attributes in the script and delete the entire row.
 I am not the best code writer, so please bare with me. This is what I have but nothing is working:
expression = ('45074.0115', '45074.0116', '45074.0117', '45074.0118', '45074.0119', '45074.0120')
with arcpy.da.UpdateCursor(MEWCo_PARCELS_UPDATE, "PID", expression) as cursor:
    for row in cursor:
        row[0] = 0
        cursor.deleteRow()‍‍‍)
I know 100% the code is written incorrectly, just not sure what part.
MEWCo_PARCELS_UPDATE is the FC
PID is the field
Thank You
JoshuaBixby
MVP Esteemed Contributor
Not to get hung up on semantics, but the title and description say "Search Cursor" but the code says "UpdateCursor".  I assume the code is correct?
Tom_Laue
New Contributor III
Yes, that is correct. You need to use update cursor to edit records whereas a search cursor is only used for read-only.
BlakeTerhune
MVP Regular Contributor
Your expession is not valid. You need to make it a string variable, include a field name, and use some kind of statement or operator with that set of values. Something like:
expression = "MyField in('45074.0115', '45074.0116', '45074.0117', '45074.0118', '45074.0119', '45074.0120')"
Also, you have numbers formatted as text. Is that correct? And I don't understand the purpose of the row[0] = 0
Clubdebambos
This will get you there. Remove the row[0] = 0 and just make sure you test on a copy of your data before you perform the delete! You are new to coding/arcpy so you need to make sure the code is working exactly as expected. Depending on your working environment you might not be able to retrieve deleted features.
~ learn.finaldraftmapping.com
