Again, thanks in advance for any help, and time. I hope this isn’t too hard to read. Basically, I am trying to do the same thing as before. I have a feature class (RSID)with a few hundred features. I would like to select each on and make it its own feature class and do stuff to it. So, I have everything done that I need to do to each RSID but I can’t seem to get the FeatureClassToFeatureClass to work. Now before, when we worked on it, there was a column NUM and an EXTENSION column that I needed and that is how we did what we did before. Now there is a NAME column that has what I need (both name and extension and when I dissolve on NAME I figure I don’t need a lot of what we had in there before. I thought that I could just search cursor through the NAME column, add “RSID” to the front of the name as I know that a feature class can’t start with a number (the NAME column looks like this ex. 789M, 801M, 541L) and make the name feature class. I am getting the ERROR 999999. I have what I did down below, and I have commented out the old code that we were using. To explain the script, I am making sure that that I have copies of feature classes and dissolving on NAME. I am than setting up some directories and feature datasets to put everything and making sure everything is correct with the slashes, than I do the searchcursor. It all works until it gets to the FeatureClassToFeatureClass. Any thoughts? I guess I haven't figured out how to copy and paste the script. The first attempt was pretty bad. The second was better but I decided just to attach it. Let me know if it doesn't work
