How would I go about setting the default GPLinearUnit parameter's units to the same as an input, or even a default value of 'meters', within a Python toolbox? I assume it happens in update Parameters, but don't know how to approach this issue.
Your help will be greatly appreciated
### From what I've been able to figure out, there is no way to choose a default linear unit such as 'meters'; however, the linear unit in the tool dialog will correspond with the active Data Frame's Map Units. I think this only works in ArcMap. At least there is an ArcCatalog Window in ArcMap now
Message was edited by: Andrew Fulton
I've been trying to figure this out as well. I've somewhat been able to get it working using updateParameters, the trick is matching its required format and units.
#For a default meters (where param[1] is your parameter with datatype GPLinearUnit)
def updateParameters(self, params):
if not params[1].altered:
params[1].values = "0 Meters"
#Updating based on an input layer (params[0]) is trickier because spatialReference.linerarUnitName doesn't match up with the GPLinearUnit types
if not params[1].altered and params[0].altered:
spRef=arcpy.Describe(params[0].valueAsText).spatialReference
params[2].values = spRef.linearUnitName
if spRef.linearUnitName == "Foot_US":
params[1].values = "0 Feet"
I'll let you know if I come across a better solution
To update a GPLinearUnit parameter (units) based on an input parameter (input) use parameterDependencies in getParameterInfo:
units.parameterDependencies = [input.name]
