Shapefile to Sql Server export
3626
05-10-2012 07:19 PM
ShwetaMorkhandikar
I need to schedule a script every week to export my shapefile and replace the corresponding SQL Server spatial data. I created the Spatial ETL tool, added it to model.
When i run this model within arcmap or arc catalog it runs without errors but when i export it to Python it gives and error. Any help is appreciated.
JakeSkinner
Esri Esteemed Contributor
Hi Shweta,
Can you attach the code?  Be sure to place it in CODE tags.
ShwetaMorkhandikar
I have attached the python script generated from model. All the sql server parameters (server, UID and Password) are supplied to ETL tool.
