Hello Randy,
Thanks for this.
Yes, we are working with shp files and not with features in a geodatabase.
We're here in this situation where we have a shp file named "earthquake_PHI.shp", and we renamed it to "earthquake_PHL.shp". This shapefile was used in over 700 mxds. we checked these mxds, and the links got broken. We wanted to find a way on how to set the data source again but with the newly renamed shpfile.
"Was there a process to the renaming that can be code?" We just renamed the shp and its extensions (.dbf, .shx, etc) manually inside a folder.
We have another situation where we didn't rename the shpfile ("earthquake_PHI.shp") anymore, instead we 'save as' another file called "earthquake_PHL.shp". In this case, we have now 2 shapefiles. Checking the mxds, links are not broken but the layer in mxd still has the old shapefile as its source, but we wanted to change it to the new shapefile by setting the data source. Is this possible with a script to set the data source in 700 mxds?
Thank you very much!
