Hi Chris,
I am getting the same attribute error, even after adding the arcpy.CheckOutExtension("DataInteroperability") into the script.
The error message.
File "G:\....\Scripts\ETL_mb_test5.py", line 21, in <module>
arcpy.SpatialETLTool_test("G:\\....\\Source42015.gdb")
AttributeError: 'module' object has no attribute 'SpatialETLTool_test'
Here is the python script:
# Import arcpy module
import arcpy
# Load required toolboxes
arcpy.ImportToolbox("G:/..../testETLtool.tbx")
# Check out extension
# Local variables:
Source42015_gdb = "G:\\.....\\Source42015.gdb"
# Process: SpatialETLTool
arcpy.SpatialETLTool_test("G:\\.......\\Source42015.gdb")
Thanks for your help.
Sri
