Speech Recognition and Arcpy
3317
07-22-2015 02:56 PM
WinnKetchum
New Contributor III
Hello All,
I've been doing some python development/scripting, trying to figure out how to complete Arcpy processes with speech recognition.  At the moment I'm using pyspeech, which utilizes windows speech recognition, and as a test I'm having it do something simply like copy a set of point features.  The script works as a stand-alone python script, however when I try to incorporate it into the pyspeech method, I get the an error that the file I'm trying to copy is not supported or doesn't exist.  Which to me is wrong, as it works otherwise.  Below are copies of the script, both with and without pyspeech, as well as the error I get when using it with pyspeech.
Thank you in advance for any help with this issue.
Winn
Code without pyspeech:
import os
import arcpy
from arcpy import env
from datetime import datetime
now = datetime.now()
Ver_Date = str(now.strftime("%m/%d/%Y"))
File_Date = str(now.strftime("%m%d%y"))
workspace = r"C:\Users\ketchum\Documents\Python Projects\Field Work Master\FieldWork.gdb"
gps_fc = workspace + "\\GPSLog_" + File_Date
note_fc = workspace + "\\Notes_" + File_Date
note_fc2 = workspace + "\\Notes_" + File_Date + "_Copy"
arcpy.AddMessage('Copying notes.')
arcpy.Copy_management(note_fc, note_fc2)
Code with pyspeech:
import speech
import arcpy
import time
speech.say('Ready for your instruction.')
print File_Date
def L1Callback(phrase, listener):
    speech.say(phrase)
    if phrase == "notes":
        speech.say('Notes have been copied.')
    if phrase == "goodbye":
        listener.stoplistening()
L1 = speech.listenforanything(L1Callback)
while L1.islistening():
    time.sleep(1)
Error when using AddNote_pyspeech.py:
072215
Copying notes.
pythoncom error: Python error invoking COM method.
  File "C:\Python26\ArcGIS10.0\lib\site-packages\win32com\server\policy.py", line 277, in _Invoke_
    return self._invoke_(dispid, lcid, wFlags, args)
  File "C:\Python26\ArcGIS10.0\lib\site-packages\win32com\server\policy.py", line 282, in _invoke_
    return S_OK, -1, self._invokeex_(dispid, lcid, wFlags, args, None, None)
  File "C:\Python26\ArcGIS10.0\lib\site-packages\win32com\server\policy.py", line 585, in _invokeex_
    return func(*args)
  File "C:\Python26\ArcGIS10.0\lib\site-packages\speech.py", line 135, in OnRecognition
    self._callback(phrase, self._listener)
  File "C:\Users\ketchum\Documents\Python Projects\Voice Recognition\AddNote_pyspeech.py", line 35, in L1Callback
  File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\management.py", line 3010, in Copy
    raise e
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000732: Input Data Element: Dataset C:\Users\ketchum\Documents\Python Proj
ects\Field Work Master\FieldWork.gdb\Notes_072215 does not exist or is not supported
Failed to execute (Copy).
DanPatterson_Retired
a question... how is the raw syntax and spaces handled by the language program ??  (ie r"c:\yourpath\yourfile.yourextension"
WinnKetchum
New Contributor III
Yes, I think the issue was that there were spaces in the pathname.  I've utilized r"pathname" before to account for this, however, it doesn't seem to work with pyspeech.  I just tried it with a pathname without spaces and it works.  Thank you for your help.
DarrenWiens2
MVP Honored Contributor
Can you use, and do you get the same error with CopyFeatures_management rather than Copy_management?
WinnKetchum
New Contributor III
I get the same error with CopyFeatures as I do with Copy.  It seems it was the pathname itself that was causing the issue.  Thank you for your suggestion though.
