In my code below, I am attempting to select features that have meet this Criteria : SNAP_FLAG (this is a field) < 3. Then I want to export these selected features as a new feature class.# Import arcpy module
import arcpy, sys, traceback
from os import path as p
arcpy.env.workspace = r"G:\ChrisGIS\PS_Steelhead\Work"
try:
for ws in arcpy.ListWorkspaces("*", "FileGDB"):
arcpy.env.workspace = ws
print '\n\nSearching in %s\n\n' %ws
# Define Variables
NB = p.join(ws, 'NB')
NB_out = p.join(ws, 'NB_Snapped')
# Figure out Query Statement enter here
query = '"SNAP_FLAG" < \'3\''
# Select
arcpy.Select_analysis(NB, NB_out, query)
print 'NB_Snapped created from %s'%NB
I then get this error :Error Info:ERROR 999999: Error executing function.An invalid SQL statement was used.An invalid SQL statement was used. [NB]The table was not found. [NB_Snapped]Failed to execute (Select).ArcPy ERRORS:ERROR 999999: Error executing function.An invalid SQL statement was used.An invalid SQL statement was used. [NB]The table was not found. [NB_Snapped]Failed to execute (Select).Any ideas what I am doing wrong? Is it the actual output table variable that is messed up, or is it my query...
