Standalone Python Script
809
09-05-2014 04:29 AM
MattZetterman
New Contributor III
So I'm a complete newbie when it comes to python. I created a python script to create a join using model builder that works great within ArcGIS. With that said I want to be able to run the script within Windows Task Scheduler and am having trouble making it work. The join is between a feature class and a table. When I look at the python script the full path for the table is created but the feature class is referenced by it's layer name without a full path. How do I create a path for the feature class? I assumed it would be something like: C:\filegeodatabase.gdb\featuredataset\featureclass but when I try running it with pythonwin I get at "Returned exit code 0".
Any thoughts on what I'm doing wrong?
JakeSkinner
Esri Esteemed Contributor
Hi Matt,
When specifying an absolute path, you will need to adjust the syntax.  Any of the following will work:
fc = r"C:\temp\test.gdb\dataset\parcels"
fc = "C:/temp/test.gdb/dataset/parcels"
fc = "C:\\temp\\test.gdb\\dataset\\parcels"
JakeSkinner
Hi Matt,
MattZetterman
New Contributor III
Works like a charm, thank you.
