Table Frames in ArcGIS Pro layout
218
04-18-2024 10:39 PM
AnsgarG
New Contributor II
Hello,
I'm trying to create a new Table Frame or update the existing one. For the caseof creating a Table Frame using CIM the project immideatly shuts down. I tried the following code:
p = arcpy.mp.ArcGISProject("current")
lyt = p.listLayouts("Layout")[0]
lyt_cim = lyt.getDefinition("V3")
tf = arcpy.cim.CreateCIMObjectFromClassName("CIMTableFrame", "V3")
tf.anchor = "BottomRightCorner"
lyt_cim.elements.append(tf)
lyt.setDefinition(lyt_cim)
For Updating the existing Table Frame i tried to set the table as fields like following code:
m = p.listMaps("Map")[0]
table = m.addDataFromPath(r"path")
for elm in lyt_cim.elements:
    if elm == "Table Frame":
        elm.fields = table
Any ideas why this isnt working?
DanPatterson
MVP Esteemed Contributor
Was your example derived from
ArcGIS Pro 2.5 CIM Samples V1 - Overview
in the section for modifying tableframe objects? or was it examples in the cim folder, for example...
C:\...install path ...\Resources\ArcPy\arcpy\cim\CIMLayout.py
... sort of retired...
AnsgarG
New Contributor II
I derived it, or rather i tried the same approach they have shown with their samples.
AnsgarG
New Contributor II
Is it maybe because of missing table frame commands for the CIM Table Frame variable?
But which of these i have to set?
CIMTableFrame Class Properties
