Hi GeoNet and thanks in advance. I'm new to Python.
My goal is to write a script that converts all the shapefiles in a gdb into a csv (although I will take an Excel spreadsheet, too). I plan to convert the final program into a script tool with parameters for which gdb to access and where to save the spreadsheets. I can get a single shapefile to convert into an Excel spreadsheet. I would like to loop through the gdb and convert each shapefile to a unique csv (for this case, let's assume that the gdb contains only shapefiles).
My code fails and I have received a couple of different error messages depending on the variable I use for the in_table argument (hope I have that right).
I suspect that I am not correctly naming my in_table and out_xls variables.
Here's a screen shot of my code. Sorry for the small size, not sure how to enlarge the text.
