Hello everyone,
I try to unzip 150 zip files which contain shapefiles. All the zip files as different names, and they all spread in one big folder that divided to a lot of sub folders and sub sub folders.i want to extract each archive to separate folder with the same name as the original zip file name and also in the same place as the original zip file . I'm working with arcview 10.3 and my code is:
import zipfile import arcpy,os,os.path,sys from arcpy import env pattern = '*.zip' folder = r"C:\Project\layers" files_process = [] for root,dirs,files in os.walk(r"C:\Project\layers"): for filenames in files: if filenames == pattern: files_process.append(os.path.join(root, filenames)) zip.extract()
After i run the code nothing happened.
Thanks in advance for any help on this.
I am confused...in your last line, you told Python to print 'zip' ... which it will do multiple times ... so as not to ruin the mystery...I assume that you wanted to have the zip file being printed rather than the word 'zip'
thanks Dan i will change it now.
All you did in this thread arcpy - Unzip files in folders and subfolders with python - Geographic Information Systems Stack Exc... is simply remove the print statement...now nothing prints...as suggested there...did anything happen? did you explore the folders to see if anything was output? If you did, then report the problem
UPDATE
this line
print 'unzip'
was originally
print 'zip'
progress is being made
i checked all folders- nothing happend
import os # needs to be added
os.listdir('c:/temp') # to print files in a folder
Nothing becomes unzip since you don't have a variable called 'zip' so zip.extract() does nothing
Research the module would help
import zipfile zipfile.ZipFile('c:/source_folder/some.zip').extractall('c:/somefolder')
thanks Dan for your helps.
this code works fine:
import logging,zipfile
from pathlib import Path
from shutil import unpack_archive
zip_files = Path(r"C:\Project\layers").rglob("*.zip")
while True:
try:
path = next(zip_files)
except StopIteration:
break # no more files
except PermissionError:
logging.exception("permission error")
else:
extract_dir = path.with_name(path.stem)
unpack_archive(str(path), str(extract_dir), 'zip')
