Update FeatureCalss Alias - the mythical arcpy.AlterAliasName
2604
04-12-2012 03:02 AM
MikeSweetman
I have a funny - if I create a feature class via import XML workspace document the alias is just the feature class name eg COUNTY, but if I create it using arcpy.CreateFeatureclass_management the alias is schema name '.' feature class name eg GISLOADER.COUNTY.
I have not found a means to set the alias when the feature class is created, and as much as I read that 10.1 will have arcpy.AlterAliasName I'm at 10.0.
Any pointers in sorting this out, using ArcCatalog or arcpy ?
cheers
Mike
MikeSweetman
For what its worth this is what I have learnt so far.
In the sde schema table sde_xml_doc1 the column xml_doc_val CLOB contains xml which is interesting.
Where my featureclass (PRUG_WKG) was loaded via xml workspace document import you would see:
      typens:Names ; PRUG_WKG ; false ; typens:PropertySet
Where my featureclass was created via a python script you would see:
      typens:Names ; false ; typens:PropertySet
So, I would imagine that is I could successfully edit this column, and probably regenrate the content of the XML_DOC BLOB column, I might get the effect I am looking for.
Anyone from ESRI wish to suggest how I do this without damaging my database ?
cheers Mike
AndrzejBieniek
In SDE schema there is a table SDE.GDB_FEATURECLASSES - you do select (ORACLE) like:
SQL> select id,name,aliasname from gdb_objectclasses where name like '%COUNCIL_WARDS_2012_RESULTS';
to find ID then update the alias and commit the changes:
SQL> update gdb_objectclasses set aliasname='NLC Councillors 2012' where id=1173;
1 row updated.
SQL> commit;
You need to refresh the connection in Arc Catalog to see your alias updated.
Have used that method several times - no problems so far.
Regards,
Andrzej
MikeSweetman
Hi Andrzej,
Thanks for the advice, I really thought I was on to a winner, BUT, in my 10.0 SDE schema I do not have a gdb_featureclasses or a gdb_objectclasses table. Are you using an earlier version perhaps?
I have looked for columns with ALIAS in their name, but only have SDE.SDE_XML_INDEX_TAGS.TAG_ALIAS.
SDE.GDB* tables I have are GDB_ITEMS, GDB_ITEMRELATIONSHIPTYPES, GDB_ITEMRELATIONSHIPS, GDB_ITEMTYPES, GDB_REPLICALOG, GDB_TABLES_LAST_MODIFIED.
thanks
Mike
AndrzejBieniek
Hi Andrzej,
Yes, we are still having SDE 9.3.1 on production server. The table might be gone in 10...
Regards,
Andrzej
