Updating rows in RowSet using UpdateCursor
1229
08-29-2014 06:42 AM
larsanundskås
I'm new to python, so bear with me
I am fetching features from a featureclass from the rest endpoint
        query = "?where={}&outFields=*&returnGeometry=false&f=json&token={}".format(where, self.token)
        fsURL = self.protocol + self.serverName + ':' + self.serverPort + url + query
        print(fsURL)
        fs = arcpy.RecordSet()
        fs.load(fsURL)
        cursor = arcpy.UpdateCursor(fs)
Then I can iterate over these rows like this:
        for row in cursor:
                print('Updating ' + key + ' to : ' + json.dumps(attributeDict[key], ensure_ascii=False))
            pass
However, I've not been able to see how I can update data on the returned rows.
Since I am fetching data through http I probably just have a local in-memory copy of these features.
Is there any "object oriented" way using arcpy, to update features through the rest endpoint?
Please advise.
Lars
FilipKrál
I have never done this before but I am guessing you could use the applyEdits end point of a Feature Service.
Apply Edits (Operation)
May I bring this python module to your attention:
arcapi/arrest.py at feature-arrest · NERC-CEH/arcapi · GitHub
It is part of arcapi package. although editing has not been implemented, the module makes it easier to interact with the REST end points.
Look at some example at the bottom. Do you have any live feature service we could try this update on?
Cheers,
Filip.
FilipKrál
Cheers,
Filip.
larsanundskås
Thanks Filip, It's not a public service.I will test the apply edits endpoint and post back my approach and results!
have a nice weekend,
Lars
larsanundskås
Something like this did the trick using applyEdits
    def writeFeatures(self, url, where, attributeDict):
        fs.load(fsURL)
        cursor = arcpy.SearchCursor(fs)
        for row in cursor:
            print('updating ' + row.getValue('AREAID'))
            features = { 'attributes': {} }
            for key in attributeDict.iterkeys():
                if attributeDict[key] != None:
                    features['attributes'][key] = attributeDict[key]
                else:
                    features['attributes'][key] = None
                pass
            features['attributes']['OBJECTID'] = row.getValue('OBJECTID')
            params = urllib.urlencode({'updates': json.dumps([features]), 'f': 'pjson', 'token': self.token})
            headers = {"Content-type": "application/x-www-form-urlencoded", "Accept": "text/plain"}
            httpConn = httplib.HTTPConnection(self.serverName, self.serverPort)
            httpConn.request("POST", self.applyEditsUrl, params, headers)
            response = httpConn.getresponse()
Thanks a lot  Filip
