Using a Python Script to Reconcile and post
5796
24
05-11-2017 04:29 PM
LarryAdgate
We are a large Water Utility Company with 38 Enterprise Geodatabases and most of them employ a versioning setup. As A workflow,  I am considering the use of a Python Script to automate the Reconcile and posting process. Can someone share with me there experience using this kind of workflow and is there a down side.
RebeccaStrauch__GISP
Probably as a .zip or a .txt file.  You probably can't do it as a response to an email or from the geonet inbox, so you will want to open the thread in a new brower tab.  I'm not seeing the "attach" button right now either (hmmm), but if the code is not too long, use the   ... At the top and the more but to pull up the syntax highlighter. Select the type and paste.  A better explaination of this is https://community.esri.com/people/curtvprice/blog/2014/09/25/posting-code-blocks-in-the-new-geonet?s...
edit: you could also post as a new document (which allows you to show versions if/when you update) or in a blog post in you space.  Then include the link here so others can find it.
CortWilson
Rebecca Strauch, GISP‌ & Larry Adgate
There are a few variables at the beginning that you will need to tailor to your environment:
editDB = (your database connection)
sqlsvrname = (name of your sql server instance)
sqldbname = (name of your sql server db within your instance)
There are several other functions and cursors that will need to have my parameters replaced with your own.  It should be pretty clear where those are though.
__author__ = 'wilson'
# Script Title: Rec_Post_GEONET
# Created by: Cort Wilson, dcortwilson@gmail.com
# Created Date: 6/1/17
# Description:  Blocks connections, disconnects users, reconcile/post versions, delete versions, unregisters tables and feature classes as versioned,
#               compresses database, registers tables and features classes as versioned, creates versions,
#               rebuild indexes, analyze datasets, set the database to allow connections.
#               pyodbc is used to log captured errors or success message into a sql table.
#       ***VERSION TREE DIAGRAM***
#                DEFAULT
#                 QAQC
#     MICHAEL   COLLECTOR   KAREN
# Requirements
# pyodbc for SQL connection and cursor to SQL log table
import arcpy
import sys
import os
import time
import pyodbc
import traceback
# \\\\Constant Vars\\\\
# Database Connection
editDB ="Database Connections/DBO@CityworksGIS.sde"
# Current Day
Day = time.strftime("%m-%d-%Y", time.localtime())
# Current Time
Time = time.strftime("%I:%M:%S %p", time.localtime())
# \\\\pyodbc.connect vars\\\\
sqlsvrname = 'gis'
sqldbname = 'CityworksGIS'
# Set workspace
workspace = editDB
# Set the workspace environment
arcpy.env.workspace = workspace
arcpy.env.overwriteOutput = True
try:
    # Start Time
    print 'Process Started at ' + str(Day) + " " + str(Time)
    # block new connections to the working and prod database.
    print "Blocking Connections..."
    arcpy.AcceptConnections(editDB, False)
    # disconnect all users from the working and prod database.
    print "Disconnecting Users..."
    arcpy.DisconnectUser(editDB, "ALL")
    # Get a list of all versions besides QAQC and DEFAULT to pass into the ReconcileVersions tool.
    ver1List = [ver1.name for ver1 in arcpy.da.ListVersions(editDB) if ver1.name != 'DBO.QAQC' and ver1.name != 'dbo.DEFAULT']
    # Execute the ReconcileVersions tool with QAQC Target Version then delete all versions besides QAQC
    print "Reconcile/post versions to QAQC...."
    arcpy.ReconcileVersions_management(editDB, "ALL_VERSIONS", "DBO.QAQC", ver1List, "LOCK_ACQUIRED", "NO_ABORT", "BY_OBJECT", "FAVOR_TARGET_VERSION", "POST", "DELETE_VERSION")
    # Extract QAQC version from the list of versions to pass to ReconcileVersions tool.
    ver2List = [ver2.name for ver2 in arcpy.da.ListVersions(editDB) if ver2.name == 'DBO.QAQC']
    # Execute the ReconcileVersions tool with DEFAULT Target Version and delete QAQC version
    print "Reconcile/post QAQC to DEFAULT..."
    arcpy.ReconcileVersions_management(editDB, "ALL_VERSIONS", "dbo.DEFAULT", ver2List, "LOCK_ACQUIRED", "NO_ABORT", "BY_OBJECT", "FAVOR_TARGET_VERSION", "POST", "DELETE_VERSION")
    print("==============================")
    print ("Unregister Tables Started")
#                                                   **** wildcards for tables I don't want to include ****
    for tbs in [tb for tb in arcpy.ListTables() if '_log' not in tb and 'GenerateId' not in tb and 'PYTHON_SCRIPT' not in tb]:
        print tbs
        arcpy.UnregisterAsVersioned_management(tbs,"NO_KEEP_EDIT","COMPRESS_DEFAULT")
# If you want to include all tables in the database use this instead:
#    for tbs in arcpy.ListTables():
#       print tbs
#       arcpy.UnregisterAsVersioned_management(tbs,"NO_KEEP_EDIT","COMPRESS_DEFAULT")
    print ("Unregister Feature Classes is started")
    datasets = arcpy.ListDatasets("*", "Feature")
    for dataset in datasets:
        fcList = arcpy.ListFeatureClasses("*","",dataset)
        for fc in fcList:
            print fc
            arcpy.UnregisterAsVersioned_management(fc,"NO_KEEP_EDIT","COMPRESS_DEFAULT")
    # Run the compress tool.
    print "Compressing database..."
    arcpy.Compress_management(editDB)
# \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ script initiation, Rec/Post process error handling \\\\\\\\\\\\\\\\\\\\\\\\\\\\\
except:
    print 'An error occured'
    failMsg = '\nSCRIPT FAILURE IN SCRIPT INITIATION OR RECONCILE-POST PROCESS, \n'
    failMsg += 'Most recent GP messages below.\n'
    failMsg += arcpy.GetMessages() +'\n'
    failMsg += '\nTraceback messages below.\n'
    failMsg += traceback.format_exc().splitlines()[-1]
    print failMsg
    #write error log info
    print 'Logging error to database....'
# THIS SECTION FOR LOGGING ERRORS TO A DB TABLE
    conn = pyodbc.connect('Trusted_Connection=yes', driver='{SQL Server}', server=sqlsvrname, database=sqldbname)
    cursor = conn.cursor()
    # You will need to create a table in sql to log to and add fields that you want to log into and pass them as params to this cursor
    cursor.execute("""INSERT INTO [dbo].[PYTHON_SCRIPT_TRACKER] (ScriptName,RunDate,Status,ErrorCode) VALUES ('ReconcilePost_AssetIDs_QAQC',GetDate(),'Failure',(?)); """,failMsg)
    conn.commit()
    conn.close()
    sys.exit()
# ////////////////////////////////////// REGISTER AS VERSIONED AND RE-CREATE VERSIONS /////////////////////////////////
try:
    print ("register tables is started")
    #                                                   **** wildcards for tables I don't want to version ****
        print tbs
        arcpy.RegisterAsVersioned_management(tbs, "NO_EDITS_TO_BASE")
# If you want to include all tables in the database use this:
#       print tbs
#       arcpy.RegisterAsVersioned_management(tbs, "NO_EDITS_TO_BASE")
    print ("register Feature Class is started")
        for fc in fcList:
            print fc
            arcpy.RegisterAsVersioned_management(fc, "NO_EDITS_TO_BASE")
    # create versions
    print "Creating Versions..."
    arcpy.CreateVersion_management(editDB, 'dbo.DEFAULT', 'QAQC', 'PRIVATE')
    arcpy.CreateVersion_management(editDB, 'DBO.QAQC', 'MICHAEL', 'PUBLIC')
    arcpy.CreateVersion_management(editDB, 'DBO.QAQC', 'KAREN', 'PUBLIC')
    arcpy.CreateVersion_management(editDB, 'DBO.QAQC', 'COLLECTOR', 'PUBLIC')
    # /////////////////////////////////// ANALYZE DATASETS AND CALC STATISTICS /////////////////////////////////////
    # NOTE: Rebuild indexes can accept a Python list of datasets.
    # Get a list of all the datasets the user has access to.
    # First, get all the stand alone tables, feature classes and rasters.
    dataList = arcpy.ListTables() + arcpy.ListFeatureClasses() + arcpy.ListRasters()
    # Next, for feature datasets get all of the datasets and featureclasses
    # from the list and add them to the master list.
    for dataset in arcpy.ListDatasets("*", "Feature"):
        arcpy.env.workspace = os.path.join(workspace, dataset)
        dataList += arcpy.ListFeatureClasses() + arcpy.ListDatasets()
    # reset the workspace
    # Concatenate all datasets into a list
    datasetList = [ds for ds in dataList]
    print "rebuilding indexes"
    # Execute rebuild indexes
    # Note: to use the "SYSTEM" option the workspace user must be an administrator.
    arcpy.RebuildIndexes_management(workspace, "SYSTEM", datasetList, "ALL")
    print('Rebuild Complete')
    print "analyzing datasets"
    arcpy.AnalyzeDatasets_management(workspace, "SYSTEM", datasetList, "ANALYZE_BASE", "ANALYZE_DELTA", "ANALYZE_ARCHIVE")
    print "analysis complete"
    #Allow the database to begin accepting connections again
    print "Set databases to allow connections..."
    arcpy.AcceptConnections(editDB, True)
# \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ If Script Successful, log into database \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
    print 'Data has been synched succesfully and logged in the tracking database'
    cursor.execute("""INSERT INTO [dbo].[PYTHON_SCRIPT_TRACKER] (ScriptName,RunDate,Status,ErrorCode) VALUES ('ReconcilePost_AssetIDs_QAQC',GetDate(),'Success','All Steps Completed Without Error'); """)
    conn.commit()
    del cursor
    conn.close()
    print 'Script is finished'
# /////////////////////////////////Register as Versioned Error handling area////////////////////////////////////////////
except:
    failMsg = '\nSCRIPT FAILURE IN VERSIONING PROCESS\n'
    print failMsg
    conn.commit()
    conn.close()
    sys.exit()
Feel free to let me know if you have any questions or find room for improvement!
My email is under the author portion of the script if you need it.
LarryAdgate
Thank You Cort, Are you going to ESRI Conference in San Diego?
Larry Adgate
CortWilson
Yes, I will be going!
Thanks Cort.  I'll take a look at it and see if it will work in our shop.  Right now, only two of us ever edit our master file, so since we have tight control and usually know of any conflict status, this might be what we need.  Anything that can speed up a routine step is very nice.
dcortwilsonpud   I'm wondering if there is a reason why you have to "UnregisterAsVersioned" ?  I know when I compress manually, I don't usually need to do this.  I do try to make sure that I am the only one connected and/or there are no locks.
Are you doing this as a way to delete the versions so you can do a clean recreation of the versions?  I'm not saying that is wrong (and may be a good thing??), but I don't think I'll need to do that.  But wanted to ask before I skip over that.
We only have two editors, but it's has a pretty complicated set of topology rules with many "exceptions".  Not that un-registering would cause a issue, but don't want to introduce that if I don't need to.  We occasionally manually delete a version, compress, and re-create.  That is mainly because I like to get it back to State 0.   Maybe that is the purpose?
CortWilson
Yep, you have it exactly right.  I should have mentioned that.
You don't have to unregister, delete, and re-create.  I do it to get a clean compress back to state 0, and because we were having some weird issues happening with our versioning at one time, and ESRI support recommended that we implement this full process to eliminate any issues.
Thanks.  I'll have to play around with whether I want to do this every time or more on-demand for our use. In any case, this will same me time on working all the logic out!
Can you share a snapshot of the SQL file structure you use for the log file?
CortWilson
I'm on SQL Server 2008.  I would think this query should work on later versions too...
USE [YOUR DB NAME HERE]
GO
/****** Object:  Table [dbo].[PYTHON_SCRIPT_TRACKER]    Script Date: 06/05/2017 13:46:51 ******/
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO
SET ANSI_PADDING ON
GO
CREATE TABLE [dbo].[PYTHON_SCRIPT_TRACKER](
     [ScriptName] [varchar](255) NULL,
     [RunDate] [date] NULL,
     [Status] [varchar](255) NULL,
     [ErrorCode] [varchar](255) NULL
) ON [PRIMARY]
GO
SET ANSI_PADDING OFF
GO
Thanks, that should work for me.  we're still on 2008 too, but testing SQL 2014 so we can upgrade to 10.5.x.
