Hello everybody,
I have an arcpy program, that performs a series of different clips on an incoming geometry. I am only interested in the result, if there are geometries in the clip's result.
To use this tool in an web application, I have published it as a geoprocessing service,
For the sake of performance I want to calculate the several clips simultaneously.
I found this tutorial:
Parallel Python: Multiprocessing with ArcPy - YouTube
So I came to this solution (compressed to the basic I hope not have cut something important):
import time
import sys, os
from multiprocessing import Pool
import logging
import arcpy
logging.basicConfig(filename=os.path.join(arcpy.env.scratchWorkspace, "../", "20181204_BQ1_I.log"), level=logging.INFO, format='%(created)f %(asctime)s %(message)s')
out_path = "in_memory"
arcpy.env.workspace = out_path
arcpy.env.scratchWorkspace = out_path
out_name_geometry = "JustAName"
spatial_reference = arcpy.SpatialReference(2056)
def clipfun(result, kind, out_geometry,timeString,sde):
arcpy.analysis.Clip(kind ,
arcpy.env.scratchGDB + "\\" + out_name_geometry + timeString,
out_geometry + "_Clip_" + kind)
rows = arcpy.da.SearchCursor(out_geometry + "_Clip_" + kind,
["SHAPE@AREA"])
result[kind+"_res"] = {}
ergebnis[kind+"_res"] = False
for row in rows:
if row[0] >= schwellwertMeter:
result[kind+"_res"] = True
break
del rows
if row is not None:
del row
return result[kind+ "_res"]
if __name__ == '__main__':
geometry_as_json = arcpy.GetParameter(0)
timeString = str(time.time()).replace(".", "_")
out_geometry = out_path + "\\" + out_name_geometry + timeString
arcpy.CreateFeatureclass_management(arcpy.env.scratchGDB,
"POLYGON",
"DISABLED",
"DISABLED",
spatial_reference)
c = arcpy.da.InsertCursor(arcpy.env.scratchGDB + "\\" + out_name_geometry + timeString, ["SHAPE@JSON"])
c.insertRow([geometry_as_json])
del c
res={
"LV_res":"",
"NkB_res":"",
"NkBW_res": "",
"DG_res":""
ps = []
funcs=[(res,"LV",out_geometry,timeString,sde),
(res,"NkB",out_geometry,timeString,sde),
(res,"NkBW",out_geometry,timeString,sde),
(res,"DG",out_geometry,timeString,sde)]
p = Pool (processes=4)
erg = p.map(callfunction,funcs)
arcpy.SetParameter(1, res["LV_res"])
arcpy.SetParameter(2, res["NkB_res"])
arcpy.SetParameter(3, res["NkBW_res"])
arcpy.SetParameter(4, res["DG_res"])
logging.info('Ende')
I can run this Tool in an arcGIS for desktop Toolbox and I can publish it to an arcGIS for server as an geoprocessing service.
But when I try to run this new service I got this error:
Fehler bei der Ausführung des Werkzeuges. ITest Job ID: j0cc0f30e501247dba8e7877929cc45ec : Traceback (most recent call last): File "D:\arcgisserver\directories\arcgissystem\arcgisinput\I2.GPServer\extracted\v101\lokal\Inventare_bestaende_ITest.py", line 255, in erg = p.map(clipfun,funcs) File "C:\Python27\ArcGISx6410.5\Lib\multiprocessing\pool.py", line 251, in map return self.map_async(func, iterable, chunksize).get() File "C:\Python27\ArcGISx6410.5\Lib\multiprocessing\pool.py", line 567, in get raise self._value PicklingError: Can't pickle <type 'function'="">: attribute lookup __builtin__.function failed Fehler beim Ausführen von (I2). Fehler beim Ausführen von (ITest).
Has anybody done something like that and can help me with this?
Tank you,
Andreas Ruloffs
