This python script selects groups of data on specific days, processes those data, and selects another group of data to process. The code executes quickly when first executed. As the code chugs along it gets slower and slower. There are no nested cursors, no nested loops - just selections and data processing. Why is code execution getting slower over time?
Any tips or tricks for preventing this type of slowdown is appreciated.
import sys
import traceback
import os
import shutil
import arcpy
import shapefile
try:
arcpy.env.overwriteOutput = True
#The input shapefile...
in_fc = r"C:\GIS\telemetrytags\projected_data\telemetryUTM.shp"
#An empty directory to store the geometric average outputs
out_dir = r'C:\GIS\telemetrytags\individual_fish_individual_days'
#For the first cursor only these fields are needed...
fields = ['TagID', 'Date']
#A list to hold all of the tag ids...
tag_ids = []
#A list to hold the survey dates
ping_dates = []
#Iterate the shapefile and get a list of all unique dates and a list of all unique tags.
with arcpy.da.SearchCursor(in_fc, fields) as cursor:
for row in cursor:
if row[0] not in tag_ids:
tag_ids.append(row[0])
if row[1] not in ping_dates:
ping_dates.append(row[1])
#Do you need to delete row now with python 3? Doing so did not speed up the code which lags over time...
del row
#This is the field list for populating the rest of the attribute table of the mean center files...
fields = ['Origin','Stock','Sex','FL','Destinatio', 'Mortality_']
#Build the query to select individual tags on individual days...
for tag in tag_ids:
for ping in ping_dates:
#Build the query...
query = '\"TagID\" = ' + str(int(tag)) + ' And \"Date\" = timestamp ' +'\'' + str(ping).split(' ')[0] +'\''
print(query)
#Select all those tags on that particular day...
this_fish, ping_count = arcpy.management.SelectLayerByAttribute(in_fc, selection_type="NEW_SELECTION", where_clause=query)
print('ping return count = ', ping_count)
#If a fish was not found on a particular day then ignore that selection...
if ping_count == 0:
pass
#If there is only one ping then just rename the original file and move it to the out_dir.
if int(ping_count) == 1:
out_fc = out_dir + "\\" + str(int(tag)) + '_' + str(ping).split(' ')[0] + '.shp'
arcpy.CopyFeatures_management(this_fish, out_fc)
#Clean up that table for the final merging of shapefiles...
arcpy.DeleteField_management(out_fc, ['MEAS','Pos_ft','CumPos_ft','Pos_RM','CumPos_RM','Time','Channel','Antenna','Power','Latitude','Longitude','NEAR_FID','NEAR_DIST','NEAR_X','NEAR_Y','Data_Inclu'])
#More that one ping on a given day needs to be averaged...
if int(ping_count) > 1:
#Build the output file and path for the averaged data...
date = str(ping).split(' ')[0]
#Create the mean center file based on the geospatial locations...
arcpy.stats.MeanCenter(this_fish, out_fc, Weight_Field='Power')
#The mean center operation output does not preserve attributes. Create them now...
arcpy.AddField_management(out_fc, 'TagID', "SHORT")
arcpy.AddField_management(out_fc, 'Date_', "TEXT", field_length='12')
arcpy.AddField_management(out_fc, 'Origin', "TEXT", field_length='3')
arcpy.AddField_management(out_fc, 'Stock', "TEXT", field_length='20')
arcpy.AddField_management(out_fc, 'Sex', "TEXT", field_length='1')
arcpy.AddField_management(out_fc, 'FL', "SHORT")
arcpy.AddField_management(out_fc, 'Destinatio', "TEXT", field_length='10')
arcpy.AddField_management(out_fc, 'Mortality_', "TEXT", field_length='20')
#These values are all the same between records, get the values to populate the out_fc...
with arcpy.da.SearchCursor(this_fish, fields) as cursor:
for row in cursor:
Origin = row[0]
Stock = row[1]
Sex = row[2]
FL = int(row[3])
Destinatio = row[4]
Mortality_ = row[5]
del row
arcpy.CalculateField_management(out_fc, 'TagID', int(tag), "PYTHON3")
arcpy.CalculateField_management(out_fc, 'Date_', "'"+ date +"'", "PYTHON3")
arcpy.CalculateField_management(out_fc, 'Origin', "'"+Origin+"'", "PYTHON3")
arcpy.CalculateField_management(out_fc, 'Stock', "'"+Stock+"'", "PYTHON3")
arcpy.CalculateField_management(out_fc, 'Sex', "'"+Sex+"'", "PYTHON3")
arcpy.CalculateField_management(out_fc, 'FL', FL, "PYTHON3")
arcpy.CalculateField_management(out_fc, 'Destinatio', "'"+Destinatio+"'", "PYTHON3")
arcpy.CalculateField_management(out_fc, 'Mortality_', "'"+Mortality_+"'", "PYTHON3")
except Exception:
tb = sys.exc_info()[2]
tbinfo = traceback.format_tb(tb)[0]
pymsg = "PYTHON ERRORS:\nTraceback info:\n" + tbinfo + "\nError Info:\n" + str(sys.exc_info()[1])
msgs = "ArcPy ERRORS:\n" + arcpy.GetMessages(2) + "\n"
arcpy.AddError(pymsg)
arcpy.AddError(msgs)
