When publishing a web tool from Pro, my tool uploads successfully. When testing the tool within WAB, I receive the following error:
fidSet = desc.FIDSet AttributeError: DescribeData: Method FIDSet does not exist
This runs perfectly fine in Pro and does not come up as an error during the publish phase. The web tool is intended to export selected images, with the portion of the script is as follows:
desc = arcpy.Describe(inView)
if fidSet:
fidList = fidSet.replace(' ','').split(';')
oidSet = set([int(oid) for oid in fidList])
else:
oidSet = set()
Any feedback would be helpful.
Thanks!
