Hi Mark,There are currently no plans for the data access (da) module to support spatial queries. However, for file geodatabases, personal geodatabases, shapefiles, etc., you can use the Select Layer By Location tool. In 10.1 final, you will be able to use a new tool named Make Query Layer which allows you create a query layer from a DBMS table based on an input SQL select statement. The SQL can include a spatial query. This layer can then be used as input to GP tools and supported by the da module. Here is an example of creating a query layer with a SQL spatial query and using it in a tool or in searchcursor.arcpy.MakeQueryLayer_management(r'Database Connections\Connection to pardy.sde', 'CMarkets', """SELECT c.mkt_id, c.shape, c.names FROM cola_markets c WHERE SDO_OVERLAPS(c.shape, SDO_GEOMETRY(2003, NULL, NULL, SDO_ELEM_INFO_ARRAY(1,1003,3), SDO_ORDINATE_ARRAY(4,6, 8,8))) = 'TRUE'""", "MKTID")
arcpy.GetCount_managment("CMarkets")
rows = arcpy.da.SearchCursor("CMarkets", "NAMES")
Jason
