Workaround: installed package crashing Pro 1.4.1
3350
7
05-31-2017 11:17 AM
ClintonDow1
Occasional Contributor II
There have been a few reports of Pro 1.4.1 crashing after packages which depend on the Jupyter/pyQT packages are installed via conda. This is due to a problematic DLL that shipped with conda which doesn't meet PEP 384. It is easy to fix, simply by deleting or renaming the culprit DLL in your active Pro environment's folder.
In your %ProInstalDir%/bin/Python/envs/arcgispro-py3 folder (or equivalent if you have created additional environments), delete or rename Python3.dll - many people are hesitant to alter DLL files, but in the same folder you will see Python35.dll - this is the one which should be loading and will fix the issue. Once this file has been removed, reopen Pro and it should work as expected.
This issue has been identified and fixed for Pro 2.0 and will not be a problem going forward. If you continue to experience issues please post to this discussion for additional support.
James_Whitacre
I was having issues with Pro crashing when trying to access a custom script tool and other tools in the Geoprocessing pane. This workaround corrected the issue as ArcGIS Pro is no longer crashing when I try to access the script tool.
What was interesting, though, is that my Python3.dll file was dated May 15, 2017, but the issue only started presenting itself in the last few days.
ClintonDow1
That was the date that the .dll was compiled for the package which was causing the issue, not necessarily when it was installed in the env.
MikeFuller2
New Contributor II
I used the suggested workaround (deleted dll file), and it stopped Pro from crashing, so thank you for that, but I ran into an issue importing pandas in the console, and I wonder if that might be related.
I tried
import pandas
and received the following error:
Runtime error
File "<string>", line 1, in <module>
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\pandas\__init__.py", line 39, in <module>
from pandas.core.api import *
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\pandas\core\api.py", line 20, in <module>
from pandas.core.reshape import (pivot_simple as pivot, get_dummies,
ImportError: cannot import name 'pivot_simple'
I would appreciate any information on the matter.
Mike
ClintonDow1
Good morning Mike,
I just tried to replicate this on a fresh install of 1.4 but was unable:
- Installed 'arcgis' package (installs Python3.dll)
- Error as described above
- Deleted Python3.dll
- Reopened Pro, no error
- 'import pandas' in the Python console in Pro & in python via cmd prompt both imported successfully
I currently have pandas 0.20.1 installed, is yours a different version number?
It may also be another package preventing pandas from updating. My 'conda list' shows:
arcgis                    1.0.1                    py35_1    esri
arcgispro                 2.0                           0    esri
bleach                    1.5.0                    py35_0
colorama                  0.3.9                    py35_0
cycler                    0.10.0                   py35_0
decorator                 4.0.11                   py35_0
entrypoints               0.2.2                    py35_1
freetype                  2.6.3                    vc14_1  [vc14]  esri
future                    0.16.0                   py35_1
html5lib                  0.999                    py35_0
ipykernel                 4.6.1                    py35_0
ipython                   6.1.0                    py35_0
ipython_genutils          0.2.0                    py35_0
ipywidgets                6.0.0                    py35_0
jedi                      0.10.2                   py35_2
jinja2                    2.9.6                    py35_0
jsonschema                2.6.0                    py35_0
jupyter_client            5.0.1                    py35_0
jupyter_core              4.3.0                    py35_0
kerberos-sspi             0.2                      py35_0
libpng                    1.6.27                   vc14_0  [vc14]
markupsafe                0.23                     py35_2
matplotlib                1.5.3              np111py35_0e  [arcgispro]  esri
mistune                   0.7.4                    py35_0
mpmath                    0.19                     py35_1
msinttypes                r26                           2    esri
nbconvert                 5.2.1                    py35_0
nbformat                  4.3.0                    py35_0
netcdf4                   1.2.4                   py35_0e  [arcgispro]  esri
nose                      1.3.7                    py35_1
notebook                  5.0.0                    py35_0
numexpr                   2.6.1              np111py35_0e  [arcgispro]  esri
numpy                     1.11.2                  py35_0e  [arcgispro]  esri
pandas                    0.20.1              np111py35_0
pandocfilters             1.4.1                    py35_0
path.py                   10.3.1                   py35_0
pickleshare               0.7.4                    py35_0
pip                       9.0.1                    py35_1
prompt_toolkit            1.0.14                   py35_0
py                        1.4.34                   py35_0
pygments                  2.2.0                    py35_0
pyparsing                 2.1.4                    py35_0
pypdf2                    1.26.0                     py_2    esri
pytest                    3.1.1                    py35_0
python                    3.5.3                         3
python-dateutil           2.6.0                    py35_0
pytz                      2017.2                   py35_0
pywin32                   220                      py35_2
pyzmq                     16.0.2                   py35_0
requests                  2.14.2                   py35_0
scipy                     0.18.1             np111py35_0e  [arcgispro]  esri
setuptools                27.2.0                   py35_1
simplegeneric             0.8.1                    py35_1
six                       1.10.0                   py35_0
sympy                     1.0                      py35_0
testpath                  0.3.1                    py35_0
tornado                   4.5.1                    py35_0
traitlets                 4.3.2                    py35_0
vs2015_runtime            14.0.25420                    0    esri
wcwidth                   0.1.7                    py35_0
wheel                     0.29.0                   py35_0
widgetsnbextension        2.0.0                    py35_0
win_unicode_console       0.5                      py35_0
xlrd                      1.0.0                    py35_0
xlwt                      1.2.0                    py35_0
zlib                      1.2.8                    vc14_3  [vc14]
Let me know if that helps.
MikeFuller2
New Contributor II
Thanks for the response! I think I had the same version of pandas, but some
of my other packages might have been out of date. I wound up
uninstalling/reinstalling and now everything is working fine.
SamMontoia1
New Contributor III
I find myself with the same issue.  I am running pandas 0.20.3.  and ArcGIS pro 2.0.  "Import pandas" in Python yields:
File "<pyshell#0>", line 1, in <module>
import pandas
I have uninstalled and reinstalled arcgis pro.  Attempted to remove or uninstall pandas using conda. I have tried to find a python3.dll, however it is not as described in the discussion above.
Conda List shows two installs of Pandas 0.20.3 along with a few others.
ClintonDow1
With the way the installer currently works, if you modify files within the Pro folder (ie by updating them with conda) then it won't remove those files when uninstalling. This is because the file hash has changed. So you're seeing two versions of pandas likely because when you reinstalled it laid down an older version beside the updated one that wasn't deleted.
Its an annoying problem and we're finding ways around it for upcoming versions. Currently you may have to manually delete the %pro%/bin/Python/envs folder when uninstalling to ensure everything is cleaned up, or manually remove that pandas version from the environments lib/site-packages directory.
