Thank you for your response.
Recommendations:
Based on your response and your script, I have the following recommendations:
- Before executing Focal Statistics, specify
- arcpy.env.cellSize to your zone raster (10m)
- arcpy.env.snapRaster to your value raster
- Before executing Zonal Statistics or Zonal Statistics as Table, you can save the output from Focal Statistics on disc, to check how much time it takes to create this raster dataset. You can also check the cell size to make sure that it is 10m (OPTIONAL).
- You can specify the output from Focal Statistics as value raster to Zonal Statistics or Zonal Statistics as Table. At this point, the output from Focal Statistics, if not saved earlier will be saved at 10m cell size, which should take substantially less time.
Comments:
I have also put together some comments below to explain my recommendations.
1. Cell size: It looks like you have not explicitly specified the environment cell size. The Zonal Statistics or Zonal Statistics as Table tool is executing with default cell size, which is Maximum of inputs. So, your Zonal Statistics output cell size is 10m. The Zonal Statistics as Table output is also calculated based on 10m cell size.
2. Focal Statistics: Since there is no analysis environment cell size specified, Focal Statistics is calculated with 0.16m cell size, resulting in a large raster. You are not immediately saving this large raster, and passing the output from Focal Statistics to Zonal Statistics or Zonal Statistics as Table. Since you are not saving the Focal Statistics output, it feels like Focal Statistics is executing quickly. In reality, Focal Statistics is returning a raster function, which stores the analytical model only, but not a raster dataset on disc.
If you are not interested in the Focal Statistics output as the final result, you can use this raster function output to another tool/raster function. However, depending on the nature of the subsequent operation, the raster function will be extended with additional analytical operation (function chain) or first a dataset will be created, and then used as input in the analytical tool.
Usually, the local and focal operations create function chain, where a raster dataset can be created by saving the final output at the end of the analysis, which makes the execution faster.
If a raster function or a function chain is used as input to zonal or global tools/raster functions, a dataset will first be created internally, before executing that in the tool. In this case, the local/focal operation is not chained together with the zonal/global operation.
3. Zonal Statistics as Table: You are specifying the output of Focal Statistics as input to Zonal Statistics or Zonal Statistics as Table. Due to the nature of the operation (zonal), the tool requires a raster dataset as value. So, it triggers the save internally, which is creating a large raster with 0.16m cell size. This raster is then internally resampled to a 10m value raster for performing the analysis with a 10m zone raster. All this extra work in Zonal Statistics as Table is probably taking the additional time, which can be avoided by specifying analysis cell size and snap raster before performing Focal Statistics.
It is not very clear yet why the tool is executing faster in Pro compared to your standalone python script. I am hoping by specifying the cell size and snap raster explicitly, you will see a performance improvement. We can then take a closer look at your workflow in Pro to understand the source of the execution time difference.
Please let me know if this works with your dataset, and if you have additional questions.
Sarmistha
