I have a small script that takes in a feature set and returns a table via. Zonal Statistics as Table. A raster that is hardcoded is used. If I create this in model builder it works fine, but in python it returns "ERROR 010024: Error during conversion"I spent a few hours troubleshooting and can't identify why it wouldn't work properly. The error refers to a conversion error, but I can't seem to see what is wrong. The Zonal Stats as Table help says it accepts a Feature Layer but not a Feature Set, however a Feature Set seems to work just fine in the Model Builder implementation.
# Import arcpy module
import arcpy
# Check out any necessary licenses
arcpy.CheckOutExtension("spatial")
inputFS = arcpy.GetParameterAsText(0)
tableResult = arcpy.GetParameterAsText(1)
downtown_solar3pt5_Year = "D:\\TorontoData\\ArcServer Published Data\\Map Data\\Toronto Solar Main.gdb\\downtown_solar3pt5_Year"
arcpy.gp.ZonalStatisticsAsTable_sa(inputFS, "OBJECTID", downtown_solar3pt5_Year, tableResult, "DATA", "ALL")
The inputFS (feature set) has a schema set in both the python and model implementations.Any help or suggestions would be appreciated!
