Not Able to Pass Where Clause in SearchCursor in ArcPy
1711
10-15-2018 09:24 PM
BehrouzHosseini
Can you please take a look at this snippet and let me know why I am not able to properly pass the Where Clause ('"[NAME_1]" = Ohio') in SearchCursor?
import arcpy
from arcpy import env
def unique_values(table , field):
 with arcpy.da.SearchCursor(table, [field], '"[NAME_1]" = Ohio') as cursor:
 return sorted({row[0] for row in cursor})
uniques = unique_values(r'C:\arcgis\ArcTutor\AAA\src\USA.shp' , 'NAME_2')
for unique in uniques:
  print (unique)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
I am getting this error on runtime
File "<module1>", line 8, in <module>
File "<module1>", line 7, in unique_values
File "<module1>", line 7, in <setcomp>
RuntimeError: Unspecified error
Same error on this format as well
with arcpy.da.SearchCursor(table, [field], '"NAME_1" = Ohio') as cursor:
curtvprice
MVP Esteemed Contributor
This syntax is incorrect for shape file query expressions. The bracket delimeter you are using on the field name "[field]" is only used for personal geodatabases (.mdb), which BTW are not supported in 64-bit arcpy (Desktop background processing or ArcGIS Pro). Text literals also need to be surrounded by quotes.
'"NAME_1" = \'Ohio\''
There are some other issues with your code but we should probably start with that.
curtvprice
BehrouzHosseini
Thanks Curtis, the code is working now but can you please let me know what are the other issues which you noticed them?
curtvprice
I took another look at your code and it seems to look okay. One thing I've done to unique-ize the list is to use list(set(mylist)) but your method of using a dictionary ({}) is pretty neat and is probably very fast!
BrittneyWhite1
I'll add that if you don't want to memorize the delimeters for each data type, you can always use the AddFieldDelimiters function:
See the section in the Specifying a query in Python help page: http://pro.arcgis.com/en/pro-app/arcpy/get-started/specifying-a-query.htm#GUID-98106084-6ECE-4647-A5...
