Hi All,
I am working on task to update MultiPatch data published as a Web Layer to ArcGIS portal, To achieve this I have written python script to overwrite Web Layer by referring to Upload Service Definition—Help | ArcGIS for Desktop .
But ended with error!!
ExecuteError("ERROR 999999: Error executing function.\nService name 'Test_Publish' already exists for '0123456789ABCDEF'\nFailed to execute (UploadServiceDefinition).\n",).
Anyone achieved this? appreciate for any ideas! Thanks in Advance. In case if i am doing something wrong please flash. Python function as below.
def publishWebLayer(market):
try:
layerName = market+"_"+"Buildings_WithInfo";
aprx = arcpy.mp.ArcGISProject('C:\\Users\\jll.innovation\\Documents\\ArcGIS\\Projects\\Lease_Services\\Lease_Services.aprx');
m = aprx.listMaps('Map')[0];
lyrs=[];
lyrs.append(m.listLayers(layerName)[0]);
serviceName = 'Test_Publish';
sddraftFile = 'C:\\Users\\jll.innovation\\Documents\\ArcGIS\\Projects\\Lease_Services\\Lease_Service.sddraft';
sdFile = 'C:\\Users\\jll.innovation\\Documents\\ArcGIS\\Projects\\Lease_Services\\Lease_Service.sd';
## Delete file if exist
if arcpy.Exists(sddraftFile):
arcpy.Delete_management(sddraftFile);
if arcpy.Exists(sdFile):
arcpy.Delete_management(sdFile);
arcpy.mp.CreateWebLayerSDDraft(lyrs, sddraftFile,serviceName,'MY_HOSTED_SERVICES', 'FEATURE_ACCESS','APAC',True,True);
arcpy.StageService_server(sddraftFile,sdFile);
arcpy.UploadServiceDefinition_server(sdFile, 'My Hosted Services',serviceName,'','EXISTING','APAC','','OVERRIDE_DEFINITION',
'NO_SHARE_ONLINE','PRIVATE','NO_SHARE_ORGANIZATION','');
except Exception as err:
exc_type, exc_obj, exc_tb = sys.exc_info()
fname = os.path.split(exc_tb.tb_frame.f_code.co_filename)[1]
print((exc_type,exc_obj, fname, exc_tb.tb_lineno));
return;
