I want to convert DecimalDegree to Point and Point to DecimalDegree.
ArcGIS runtime V10.2.6 have CoodinateConversion class , but V100 is don't have?
Where is it ?
Thank you.
This is now available in 100.1 release with the CoordinateFormatter class - CoordinateFormatter Class | ArcGIS for Developers
Coordinate conversion is not available in the 100.0 release of ArcGIS Runtime. We plan on having it for an upcoming release. What are you trying to convert to/from right now?
I have the same problem. I used it to convert geo coordinates (lat/lon) to map coordinates and vica versa. Is there functionality available or do I have to write my own converter class?
It will be included in the next update of version 100, which is out in approximately May/June of this year.
Hello Lucas,
We are currently mid June.
Do you have any information when the next update of version 100 - including CoordinateConversion !!! - will be released ?
Thanks for keeping us up-to-date.
Marc
Hey Marc, we are just about done with Update 1! Watch GeoNet for a blog with release details shortly.
Hi Lucas,
Thanks for keeping me up to date !
Looking forward to the new /renewed functionalities in the update.
Thanks for the update !!!
You're welcome. Here is a sample to help you get started arcgis-runtime-samples-qt/ArcGISRuntimeSDKQt_CppSamples/Geometry/FormatCoordinates at master · Esri/...
