Cannot load local exploded tile cache
4395
5
03-26-2015 08:11 AM
MarcoPiccolino1
Hi there,
we made a small test by loading a tiny tile cache generated by Arcgis Server 10.2.2 both in compressed  and exploded formats.
The compressed tiles (C) display just fine, however the exploded ones (X) do not show up.
See the attached packages.
Thanks a lot,
Marco
LucasDanzinger
Esri Frequent Contributor
Marco-
It looks like this is a documentation bug. We only support working with TPKs directly or compact tile caches. Exploded tile caches are not supported in the Runtime. This is consistent across all of the Runtime APIs. We will be updating the doc to reflect this.
Sorry for the confusion.
-Luke
MarcoPiccolino1
Here is the calling code (QML):
Map {
     anchors.fill: parent
     wrapAroundEnabled: true
          ArcGISLocalTiledLayer {
          path: ArcGISRuntime.installDirectory + "/sdk/samples/data/TestCacheC"
LucasDanzinger
Marco-
Which property do you call on export tiles to give you the "exploded" version?
Luke
LucasDanzinger
Nevermind, I see the option in ArcMap. I'll take a look into this.
LucasDanzinger
Marco-
-Luke
MarcoPiccolino1
Luke, thanks for checking -- of course this is very disappointing 🙂
M
