I have a .tif file and an extra .tfw file. How can I load the .tfw file?
From this post I could see how to load the .tif file:
https://community.esri.com/thread/93016?sr=stream&ru=3159
But how can I go further and load the corresponding .tfw file?
In ArcMap it is automatically done, but not in the ArcGIS Runtime SDK for Qt.
It works now
Yes, this was my problem. I didn't undestood that everything is based on one spatial refernce. I changed the SpatialReference now to 4326 and it worked well. (Except that the default map is not shown any more...But this is because it is based on another SpatialReference (3857).)
Thank you very much
