Updating point feature problem qt/qml
2771
02-25-2016 05:17 AM
tanerkoka1
I'm using GeodatabaseFeatureServiceTable service to update point feature in online side. But I can't update my point feature to another place.Point moves to other place but can't apply feature edits back to the service and applyFeatureEditsErrors  object is undefined when trigger onApplyFeatureEditsErrorsChanged event in GeodatabaseFeatureServiceTable  .Are there any wrong code in my app.Here is the app and console output below.
Thanks.
import QtQuick.Controls.Styles 1.2
import ArcGIS.Extras 1.0
import QtQuick 2.3
import QtQuick.Controls 1.2
import ArcGIS.Runtime 10.26
ApplicationWindow {
    width: 800
    height: 600
    title: "Test"
    property double scaleFactor: System.displayScaleFactor
    property int fontSize: 15 * scaleFactor
    property string featuresUrl: "http://........................./arcgis/rest/services/....................../.........................."
    property var selectedFeatureId: null
    Envelope  {
        xMin: 3430342.171241454
        yMin: 4671974.99845585
        xMax: 3775017.817877803
        yMax: 4976536.316803186
    Map {
        anchors.fill: parent
        extent: sfExtent
        focus: true
        ArcGISTiledMapServiceLayer
            url: "http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"
            opacity: 0.5
        ArcGISDynamicMapServiceLayer
            url: "http://........................................./arcgis/rest/services/................../.............."
        FeatureLayer {
           featureTable: featureServiceNumaratajTable
           selectionColor: "cyan"
            function hitTestFeatures(x,y) {
                var tolerance = Qt.platform.os === "ios" || Qt.platform.os === "android" ? 4 : 1;
                var featureIds = onlineNumaratajLayer.findFeatures(x, y, tolerance * scaleFactor, 1);
                if (featureIds.length > 0) {
                    selectedFeatureId = featureIds[0];
                    selectFeature(selectedFeatureId);
                    statusText.text = "Feature Selected.Please Update Point";
        onMouseClicked:
            if (onlineNumaratajLayer.isFeatureSelected(selectedFeatureId))
                var featureToEdit = onlineNumaratajLayer.featureTable.feature(selectedFeatureId);
                featureToEdit.geometry = mouse.mapPoint;
                onlineNumaratajLayer.featureTable.updateFeature(selectedFeatureId, featureToEdit);
                onlineNumaratajLayer.unselectFeature(selectedFeatureId);
               featureServiceNumaratajTable.applyFeatureEdits();
               statusText.text="Editing is complated";
                selectedFeatureId = null;
            } else
                onlineNumaratajLayer.hitTestFeatures(mouse.x,mouse.y);
    GeodatabaseFeatureServiceTable {
        url: featuresUrl + "/1"
onApplyFeatureEditsErrorsChanged:
   console.log("Error Edit Operation String :"+applyFeatureEditsErrors.editOperationString);
    console.log("Error Edit Operation :"+applyFeatureEditsErrors.editOperation);
    Rectangle {
        anchors {
            fill: statusText
            margins: -10 * scaleFactor
        visible: statusText.text.length > 0
        color: "lightgrey"
        radius: 5
        border.color: "black"
        opacity: 0.77
    Text {
        anchors {
            left: parent.left
            right: parent.right
            bottom: parent.bottom
            margins: 20 * scaleFactor
        wrapMode: Text.WordWrap
        color: "black"
    Rectangle {
        color: "transparent"
        border {
            width: 0.5 * scaleFactor
            color: "black"
Console output:
Starting D:\Projects\Packages\QT\build-OfflineNumtest-Desktop_Qt_5_4_2_MSVC2013_64bit-Release\release\OfflineNumtest.exe...
Initializing application
ArcGIS.Extras.Plugin: void __cdecl ArcGISExtrasPlugin::registerTypes(const char *) ArcGIS.Extras
ArcGIS.Extras.Plugin: void __cdecl ArcGISExtrasPlugin::registerTypes(const char *) Registering Singleton Types
ArcGIS.Extras.Core: void __cdecl TkTypes::registerTypes(const char *) ArcGIS.Extras
int __cdecl main(int,char *[]) ApplicationWindow_QMLTYPE_12_QML_15(0x21c40d0)
qt.network.ssl: QSslSocket: cannot resolve TLSv1_1_client_method
qt.network.ssl: QSslSocket: cannot resolve TLSv1_2_client_method
qt.network.ssl: QSslSocket: cannot resolve TLSv1_1_server_method
qt.network.ssl: QSslSocket: cannot resolve TLSv1_2_server_method
qt.network.ssl: QSslSocket: cannot resolve SSL_select_next_proto
qt.network.ssl: QSslSocket: cannot resolve SSL_CTX_set_next_proto_select_cb
qt.network.ssl: QSslSocket: cannot resolve SSL_get0_next_proto_negotiated
qml: Error Edit Operation String :undefined
qml: Error Edit Operation :undefined
LucasDanzinger
Esri Frequent Contributor
Taner-
Instead of
Can you do
console.log("Error Edit Operation :"+applyFeatureEditsErrors.error.description);
Instead?
Maybe that will give more ideas.
-Luke
tanerkoka1
Here is the consoe output of console.log("Error Edit Operation :"+applyFeatureEditsErrors.error.description); code:
qrc:/qml/main.qml:122: TypeError: Cannot read property 'description' of undefined
tanerkoka1
I add also onApplyFeatureEditsStatusChanged event in GeodatabaseFeatureServiceTable  like below.When I update feature applyFeatureEditsStatus status is  2 (Complatet) but my feature is the same location on the server.
App:
onApplyFeatureEditsStatusChanged:
console.log(applyFeatureEditsStatus);
Console Olutput:
qml: 2
LucasDanzinger
Perhaps you could use Fiddler to capture the http network traffic and see if the proper information is being sent to the server? Note that you will need to set up proxy to point to local host in order to do this -- ArcGIS Runtime SDK for Qt QML API: ArcGISRuntime Class Reference
