I do it like this because I use LRS. With this script I can use my routes with measures to create points at different increments for different LRS Reference Methods:
pydot/HatchFake.py at master · KDOTGIS/pydot · GitHub
Created on Jul 14, 2015
This script will create route events as points along the route features at specific increments
the points can be symbolically displayed as route hatches for web mapping
@author: Kyle Gonterwitz with, as always the amazing help from Dirk Talley
@contact: Kyleg@Ksdot.org
#import arcpy
from arcpy import (AddField_management, MakeFeatureLayer_management, CreateTable_management,da, Exists, AddXY_management,
TruncateTable_management, Append_management, MakeRouteEventLayer_lr, Delete_management, FeatureClassToFeatureClass_conversion, env)
#set the geodatabase parameters for the input route data
env.overwriteOutput = True
wsPath = r"Database Connections\shared@SQLGIS_cansys_gis_dev.sde" #enter the workspace path that has the data owner login
StatefcRoutes = r"\\gisdata\arcgis\GISdata\Connection_files\RO@sqlgisprod_GIS_cansys.sde\GIS_CANSYS.SHARED.SMLRS" # State Route feature class with begin/end attribs
CountyfcRoutes = r"\\gisdata\arcgis\GISdata\Connection_files\RO@sqlgisprod_GIS_cansys.sde\GIS_CANSYS.SHARED.CMLRS" #County Route Feature Class with begin/end attribs
#State and County are the Two main Linear Referecing Methods used by KDOT which will be hatched
StateOutTable = "SMHatch"
CountyOutTable= "CMHatch"
StateFields = ["LRS_Route", "BEG_STATE_LOGMILE", "END_STATE_LOGMILE"]
CountyFields = ["LRS_KEY", "BEG_CNTY_LOGMILE", "END_CNTY_LOGMILE"]
#this field sets the hatch separation/spacing. For a hatch point every 1/10 of a mile, enter 0.1. For a hatch every 1/100th of a mile, choose 0.01.
#for mapping in KanPlan 1/10 mile seems plenty sufficient, and will create about 108,000 points for each LRM.
#1/100 would create 1,080,000 points which might suffer from use of in-memory processing, already this script takes a few minutes to run for each LRM
HatchSep = 0.1
countyLRM = [CountyfcRoutes, CountyOutTable, CountyFields]
stateLRM = [StatefcRoutes, StateOutTable, StateFields]
LRMethod = [countyLRM, stateLRM]
for method in LRMethod:
print "creating hatches for " + str(method[1])
#add route table as feature layer
if Exists("RouteLyr"):
Delete_management("RouteLyr")
else:
pass
MakeFeatureLayer_management(method[0], "RouteLyr", "DIRECTION in ( 1 , 2 )")
#create event table in memory
mem_table = "HatchEvents"
if Exists(r"in_memory\\"+mem_table):
print str(mem_table) +"already existed, deleting"
Delete_management(r"in_memory\\"+mem_table)
else:
print "Creating table for processing route increments of " + str(HatchSep)
CreateTable_management("in_memory", mem_table)
mem_table = r"in_memory\\"+mem_table
AddField_management(mem_table, "RouteID", "TEXT")
AddField_management(mem_table, "LogMile", "Double")
for row in sorted(da.SearchCursor("RouteLyr", (method[2]))): # @UndefinedVariable
LRSKEY = row[0]
if LRSKEY == (LRSKEY):
# use this loop to test the script against a single route
iter0 = row[1]
#print row[0]+ ' from '+str(row[1])+' to '+str(row[2]) #print the current LRS Key
#set the begin and end parameters from which to create incremental values
if HatchSep == 0.1:
round_dec = 1
elif HatchSep == 0.01:
round_dec = 2
else:
round_dec = 0
print "check hatch separation value"
minlog = round(row[1], round_dec)
if minlog > row[1]:
minlog = minlog - HatchSep
else:
pass
maxlog = round(row[2], round_dec)
if maxlog < row[2]:
maxlog = maxlog + HatchSep
else:
pass
#set the starting point for the route segment
itermile = minlog
#now loop between the start and end logmiles for each route segment, and insert the step increment into the event table in memory
while itermile <= maxlog and itermile >= minlog:
#print str(itermile)
with da.InsertCursor(mem_table, ("RouteID", "LogMile")) as insert:# @UndefinedVariable
insertfields = [LRSKEY, itermile]
insert.insertRow(insertfields)
itermile = itermile + HatchSep
del minlog
del maxlog
MakeRouteEventLayer_lr("RouteLyr", method[2][0], mem_table, "RouteID POINT LogMile", "HatchPoints_events", "", "ERROR_FIELD", "ANGLE_FIELD", "NORMAL", "COMPLEMENT", "LEFT", "POINT")
#add XY points, later on these coordinates can be used to hyperlink to google street view, bing maps, etc. Make sure we are in NAD83 Lat/Long CRS here.
AddXY_management("HatchPoints_events")
try:
Delete_management(wsPath+'//'+method[1])
FeatureClassToFeatureClass_conversion("HatchPoints_events", wsPath, method[1], "LOC_ERROR = 'NO ERROR'")
except:
TruncateTable_management(wsPath+'//'+method[1])
Append_management("HatchPoints_events", wsPath+'//'+method[1])
cleanup = [mem_table, "RouteLyr", "HatchPoints_events"]
for layer in cleanup:
Delete_management(layer)
