Get line direction/orientation as a numeric field
43396
15
05-01-2011 08:48 PM
AlanAitken
Should be a simple one here.
How do I get ArcGIS 10 to return the orientation (or direction) of each line in a polyline feature into a field.
what do I need to type into field calculator (or is there a better way)
Ta
Alan
FrédéricPRALLY
To calculate angle of lines fill calculate values with parser python using this python line:
180 + math.atan2((!Shape.lastpoint.Y! - !Shape.firstpoint.Y!),(!Shape.lastpoint.X! - !Shape.firstpoint.X!)) * (180 / math.pi)
Hope this help you,
Best regards,
Fred
AlanAitken
Thanks Fred,
Trig seems obvious now, but good to get the python syntax
Works
Alan
SteveFeeney
New Contributor II
Is there any means to attribute a field of a Polyline with the line bearing within a model? I have a model I need to package and distribute to other operators who are still using 9.3. Ideally it needs as few add-ons as possible to function.
Thank you,
Steve
SteveFeeney
New Contributor II
Please disregard my last post.
Some revision and self education later and I can see it has already been answered above.
When I input the python code, I'm using the "Calculate Field" management tool with expression type as "Python 9.3". The function calculates fine but returns different values to the ones I manually measured using MA. Am I using it correctly?
Kind regards,
Steve
AlexanderBeavis
New Contributor II
So does this code provide the bearing of a polyline with reference to north?
chriss_
New Contributor II
Hi!
I wanted to use the Code to define the deviation from north in degree. Where north would be 0 east 90 south 180 and west 270. So I changed the code to this:
180 + math.atan2((!Shape.lastpoint.X! - !Shape.firstpoint.X!),(!Shape.lastpoint.Y! - !Shape.firstpoint.Y!)) * (180 / math.pi)
So far so good, BUT for everything in western direction I get a negative value eg. -90 instead of 270.
Any mathematical genius that can enlighten me?
Thanks
Chris
BradyCallahan
New Contributor III
The radians thing didn't help me either so I used this to return a North Azimuth based reference. Hope it helps someone...
Field (type double) = NorthAzimuth( !Shape! )
Codeblock:
def NorthAzimuth(Pline):
  degBearing = math.degrees(math.atan2((Pline.lastPoint.X - Pline.firstPoint.X),(Pline.lastPoint.Y - Pline.firstPoint.Y)))
  if (degBearing < 0):
      degBearing += 360.0
  return degBearing
by Anonymous User
Not applicable
Thank you! it worked !
SteveFeeney
New Contributor II
This may be a bit basic,
There is a tool called 'Linear Directional Mean' that will create and populate a compass bearing field with the mean direction of a shapefile/featureclass or, if you use a unique field, for each feature.
As far as I can tell it is planar rather than geodesic but it's a sound, quick fix and saves coding trig.
