I am attempting to iterate many point feature classes for a kriging analysis. What is the best way to loop/iterate this process for many feature classes stored within a personal GDB?
Hi Ron,
An ESRI Raster GRID is limited to 13 characters for the name length. See the section 'Storage Limitations' within the following link:
Esri Grid format—Help | ArcGIS Desktop
If you are running into this limit I would recommend using a different raster format, such as a .TIF. You can do this by simply appending .tif to the end of the raster name.
Hi Ron,
Thank You Jake. I was unsure about the amount of characters allowed for a raster name. I am now moving forward with iterating the feature classes for the Kriging Analysis.
