The output from the ModelBuilder process is as follows:
Executing (Make NetCDF Raster Layer (25)): MakeNetCDFRasterLayer "D:\Todd Research\GIS Datasets\Climate_Projections\CMIP_5_Data2\Monthly\RCP_4.5\Precipitation\BCSD_0.125deg_pr_Amon_bcc-csm1-1_rcp45_r1i1p1_200601-209912.nc" pr longitude latitude Precip_bcc-csm1-1_RCP45_Dec2025 # "time '12/16/2025 12:00:00 PM'" BY_VALUE
Start Time: Wed Jun 21 14:52:43 2017
Succeeded at Wed Jun 21 14:52:43 2017 (Elapsed Time: 0.12 seconds)
Executing (Project): Project "D:\Todd Research\Processing\Chesapeake_Bay.gdb\Somerset_County_MD_2016" "D:\Todd Research\Processing\Chesapeake_Bay.gdb\Somerset_County_MD_2016_WGS84" PROJCS['WGS_1984_World_Mercator',GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Mercator'],PARAMETER['False_Easting',0.0],PARAMETER['False_Northing',0.0],PARAMETER['Central_Meridian',0.0],PARAMETER['Standard_Parallel_1',0.0],UNIT['Meter',1.0]] WGS_1984_(ITRF00)_To_NAD_1983 GEOGCS['GCS_North_American_1983',DATUM['D_North_American_1983',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]] NO_PRESERVE_SHAPE # NO_VERTICAL
Succeeded at Wed Jun 21 14:52:44 2017 (Elapsed Time: 1.66 seconds)
Executing (Clip (159)): Clip Precip_bcc-csm1-1_RCP45_Dec2025 "283.763542 37.886605 284.460367 38.298944" "D:\Todd Research\Processing\Tangier_Smith_Islands.gdb\Precip_bcc-csm1-1_RCP45_Dec2025_Somerset_MD_WGS84" "D:\Todd Research\Processing\Chesapeake_Bay.gdb\Somerset_County_MD_2016_WGS84" 1.000000e+020 NONE NO_MAINTAIN_EXTENT
Start Time: Wed Jun 21 14:52:45 2017
ERROR 999999: Error executing function.
The table name is invalid.
No spatial reference exists.
FDO error: -2147220948
The table was not found. [Precip_bcc-csm1-1_RCP45_Dec2025_Somerset_MD_WGS84]
Failed to execute (Clip (159)).
Failed at Wed Jun 21 14:52:45 2017 (Elapsed Time: 0.14 seconds)
