Point density analysis
190
03-03-2024 09:12 PM
d1onel
I have a point layer and each of the points is either category A or B. I want to find out if proximity to category B helps category A increase in weight.
I have separated the file into two layers now; layer A (I have the weights of each point as a field here) and layer B. What sort of analysis can I do in ArcGIS Pro to answer this question?
I want something like checking if a category A point is closer to a cluster of category Bs, it perhaps grows heavier or not. Can anyone share ideas for how to achieve this in Arcgis? I'd appreciate it.
RonaldHaug
Occasional Contributor II
Hi d1onel!
Interesting proposition. The closer I live to the candy store the fatter I get. Something like that?
Yes you could probably make something of that.
I would look into correlation, causation, inverse distance weighting, and Tobler's Law.
https://support.esri.com/en-us/gis-dictionary
Let us know what you find out.
