Splash Widget no longer loads in website
984
09-27-2016 05:53 AM
SeanMetrick2
Hi there,
I have embedded a web app map in a wordpress page. It has always had a splash, and it has worked fine, even when I edit the splash. For some reason, after my most recent edit, the splash no longer loads in the website when using a browser or a mobile device. It works when I view it in arcviewer though, and if I hide the splash from view the map loads perfectly in the website.
If anyone could offer any suggestions I would greatly appreciate it.
Tags (3)
AdrianWelsh
MVP Honored Contributor
Sean,
It might be helpful to move this post to a more appropriate place in order to get the correct responses. Community help is for help with the GeoNet, mostly. See https://community.esri.com/docs/DOC-2258 for assistance with this.
Is this something you made in Web AppBuilder? Is this a custom web map/app? Is this an out of the box web app? Can you post the website in which this is to load? Can you post a link to the web map/app?
