Hi Cara Joos,
WhatDavid Pike's mentioned above is right.
However, if you are after tools out of the toolbox, you can use Dissolve tool for the polyline provided that it has a field with the same value so that you could use it as a dissolve parameter/field to aggregate features. you can add a field with same values if it's not already there.
Once the polyline feature class is aggregated (continuous), use the Feature to Polygon tool.
Note that sometimes just using the Feature to Polygon tool will do the split without using the Dissolve tool, depending on your polyline feature class.
I hope that's helpful.
Cheers.
