Hotspot analysis
977
5
08-21-2017 03:07 PM
NiloufarShirani
I want to do Hotspot analysis for crash data, How should I define the threshold distance?
DanPatterson_Retired
hot-spot-analysis.... there is a discussion link within there as well.  This is for Pro since you didn't specify software version.. arcmap has a similar link with the same information
OriGudes2
You may want to check my recent study titled:
Investigating articulated heavy-vehicle crashes in Western Australia using a spatial approach might be helpful?
Regards Ori
OriGudes2
Ori... perhaps you can summarize.  The average user on GeoNet will have to buy the article unless they are an academic and their institution has access to Science Direct through an institutional license agreement.  I don't suppose you have anything published along the same lines in an open access journal?
OriGudes2
You are right, I will look for an open report I can share, this one is open access and could be of a value for the threshold question: Identification of crash hotspots using kernel density estimation and kriging methods: a comparison |...
