Great to know that the sample script is working on 10.2.2! It looks like your zip file only has the toolbox though (instead of both the script and the toolbox). If Ori is using your zip file, that is definitely the reason he is getting an error about not finding the script. If Ori is using the zip file I attached, then Phillip's suggestion to make sure the script path is correct is a good one! Here's how: once you navigate to the Temporal Collect Events toolbox, right click on the tool and select "Properties"... then on the "Source" tab, check to make sure the path to the temporalcollectevent.py script file is correct... if it isn't, browse to the .py file to set the correct path.
Ori: if you still have problems, please send the screen shot to my email, LScott@esri.com, and I will see if I can figure out what's what.
Thanks!
Lauren
