And, if I may add, using the OID of the feature as a join item is a bad idea.
It could change if you edit the feature.
If this is a once off, as Adrian has said, add a new item to your feature and calculate the OID across to it.
And, I hope that in the join table the join item is not called OID or OBJECT_ID or anything like that.
