I'm trying to use Attribute Assistant in my organization, and I'm trying to get AssetIDs to populate based on this rule, but it won't work. Any ideas?
Table Name: sdManhole
Field Name: ASSETID
Value Method: GENERATE_ID_BY_GRID
Value Info: MapIndex|PageName|Seq_Num|[id][seq]
SYSID generation is working perfectly. I turned on debugging in the config file and receive this error (despite getting a message box from AA that all operations succeeded):
Row Info
Row Number 1
TableName: sdManhole
FieldName: ASSETID
ValueInfo: MapIndex|PageName|Seq_Num|[id][seq]
ValueMethod: GENERATE_ID_BY_GRID
On Create: 1
On Change: 1
Checking for Subtype Restriction
Field Name: ASSETID was found at index: 4
ERROR: GENERATE_ID_BY_GRID for layer sdManhole is not a valid method, check the dynamic value table
Any help would be much appreciated in this matter.
