I am currently updating to the latest and greatest Attribute Assistant that includes the columns "on change geo" and "on change Attribute" in the Dynamic table. The problem I'm having is with Prompts. I have set up all Prompts to "on create" only, but when I edit an existing feature it will trigger Prompts for any field that the existing feature doesnt have populated (<Null>'s). So the prompt is set to "on create" yet it will promp existing features if I touch them, even with all other Dynamic table fields set to false. Is this supposed work that way? I would like the prompts to only trigger "on create" as they did in the slightly older download. Any ideas? I've included a sample of my Dynamic table for review. Thank you!
[ATTACH=CONFIG]26918[/ATTACH]
I was troubleshooting with different scenarios and found out that this prompt problem has something to do with the "Run Create Rules for Selected Feratures" when I've I've used it prior to editing other existing features. I open my mxd and start editing, if I want to edit an existing feature, no prompts are triggered (the way it should be). Then, if I select a feature and run the "Run Create Rules..." button it'll run the rules as planned, but after that if I edit another existing feature, the same "on create" rules apply like I clicked the "Run Create Rules..." button again though I didn't. the only way to stop this process is to shut down my mxd. Does this "Run Create Rules" button act as a toggle-on/off?
